MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
ACS/DCS, what does the MTH really do with these.
Old Sep 26, 2005 | 12:34 PM
BabyHueyVFR's Avatar
BabyHueyVFR
I have a 2003 MINI Cooper, not an S, just loaded the turner file, that does not have any switches for ACS or DSC. I have seen that the MTH file added ACS, or DCS depending on who said it and in what thread.
So since there is not switch in my cockpit, can anyone say for sure if the turner file activated either of these?
Thank you,
Old Sep 26, 2005 | 01:56 PM
glassintrepid's Avatar
glassintrepid
You cannot activate the DSC on a car that did not come with it from the factory. If there is no switch that you dont have DSC or ASC. It only changes the force that the ASC kicks in by like 50nm if you have it.
Old Sep 26, 2005 | 04:12 PM
tradiuz's Avatar
tradiuz
MTH Specialist
ASC / DSC are factory options. DSC actually has a harware component.
MTH does not add ASC or DSC but it modifies the parameters to be less intrusive. I personally found the DSC from the factory way OVER intrusive, and almost dangerous, since it would always kick in when I was turning into traffic from a stop.
Old Sep 27, 2005 | 01:47 AM
Bster's Avatar
Bster
Diff?
So whats the difference between DSC and ASC?
Old Sep 27, 2005 | 04:32 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
ASC only remove torque from engine when a wheel spins, or the car gets out of control.
DSC uses ASC and all 4 brakes to control the car.
Old Sep 28, 2005 | 04:55 AM
blalor's Avatar
blalor
DSC also has yaw and steering input sensors; it can better "detect" what you're intending to do and help the car follow through. For example, if the rear starts to step out to the right in a fast left-hander, DSC will apply the inside-rear brake to help pull the car around the corner.
Grizld700
Nov 8, 2016 05:14 AM
64van
Tires, Wheels, & Brakes
Sep 24, 2015 07:31 AM
64van
Factory JCW Talk (2009+)
Sep 20, 2015 12:23 PM
Elusiv
Sep 14, 2015 11:23 PM
Ladybug-S
Sep 10, 2015 07:08 PM
