MINI5280 The Motoring Society of the Rocky Mountain Region. Visit the club site at www.mini5280.org and Event Calendar.
Leaking MINI
Old Jun 15, 2012 | 08:40 AM
No0dle's Avatar
No0dle
Leaking MINI
Anyone have/had water issues? My friend's MINI is soaked and it looks like it's dripping from the HVAC system thing in front of the car. It got so bad that she had to pull carpet out. Any ideas?
Old Jun 15, 2012 | 10:18 AM
old81's Avatar
old81
M6
Check the water drain lines if it is leaking into the cabin, might be plugged and backing up.
Is this after a car wash or normal driving on a hot day with the air on full. Drain line for AC, broken, plugged?
Just some thoughts, what year and model MINI?
Don
Old Jun 17, 2012 | 09:48 AM
No0dle's Avatar
No0dle
This is what from her:
Normal driving only when AC is on. Leaked into the front floor board area and eventually into the back. Drain tube isn't blocked and drains fine- we used compressed air to clean it out before.
Year-2006 model cooper s w JCW upgrades. and less than 60k on it!
No leaks from any of the weather stripping.
Weird thing- we let the AC run on Max for 10 minutes- no leak, we did this 3 times.
Driving down the road though there's leak.
no sunroof. I know that's probably anther question
Thanks again
Old Jun 17, 2012 | 11:55 AM
MINIdave's Avatar
MINIdave
Sounds like the opening from the drain tray to the tube is blocked, use a coat hanger wire and poke it up into the tray thru the drain tube hole and see if you get a bunch of water. if so you need to remove the tray and clean it. If it's clogged up it's probably smelly too.....
KrisMiss
Jan 3, 2016 02:02 PM
johntotah94
Oct 19, 2015 02:20 PM
wind715
Aug 11, 2015 07:56 AM
ti22fjc
Aug 9, 2015 05:49 PM
USA-RET
Aug 6, 2015 09:22 PM
