FS:: Adjustable Rear Control Arms Links, Mini Cooper w/Boots. Easy Alignment & Camber
Old Mar 13, 2013 | 03:58 PM
Scott Kuo's Avatar
Scott Kuo
Category: Suspension
Price: $150
Part fits (you may select multiples): R53, R56, R57
Location (Region): SoCal
Item Condition: Brand New
I have 2 brand new lower adjustable control amrs for sale. I bought these from Ebay.
my tech guy told me my camber is fine and dont need to adjust.
asking $150 shipped.
One Set of two (2) Adjustable rear control arm links with protective rod-end boots for Mini Cooper 2002-2012
These arms, are constructed of 1 inch (25.4mm) diameter x .095 inch (2.4mm) wall steel tubing. . Each arm has a RH and LH thread precision rod-end bearing and lock-nut to provide easy adjustment. The arms are pre-adjusted to factory length, but can be shortened or extended to provide the rear wheel camber you want. The threads have been pre-treated with anti-seize compound to insure easy adjustability in the future.
The rod-ends bearings are nylon-composite-lined to assure good self-lubrication and should be maintenance free. With the boots and the pre-applied grease, future lubrication, except in the most severe conditions, should not be needed. These rod ends are rated slightly in excess of 27,000lbs static radial load.
The rod-end boots are a tough, flexible neoprene rubber. They are resistant to gasoline and most oils and greases. The boots come pre-installed and pre-packed with a high load, water-resistant moly grease. And they are replaceable should they get damaged at some future time.
Due to design of the Mini, you can use these in either the upper or lower position, or both. If only installing one set, most people usually replace the factory lower arms. This enables you to adjust camber only. Installing these in both positions will enable adjustment of camber and tracking of the rear wheels. If your Mini is equipped with self leveling Xenon headlights, you may want to consider our sensor arm attachment. This is mounted on the upper drivers side arm.
Even if you leave these arms at the factory settings, you will notice a difference when aggressively cornering. The rod ends, while self-aligning have the added benefit of having no give, unlike the factory rubber bushings. At about 5lb 12 oz/set, they are about one pound lighter than the factory arms.
Easy to install. It takes about an hour per set, needing only common hand tools and the appropriate jacks. Instructions are included.
The factory center-to-center hole distance is 532mm, or about 20 15/16 inches. The maximum recommended length on these arms is 551mm, or about 21 11/16 inches.
Attached Thumbnails Adjustable Rear Control Arms Links, Mini Cooper w/Boots. Easy Alignment & Camber-kgrhqr-lye2ejy-y-bbnozlqrdhq-_3.jpg
Old Jul 26, 2013 | 08:02 AM
Candu61's Avatar
Candu61
Do you still have these and would you ship to Canada for 150.
Thank you,
Bruce MacAulay
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
