Mini/MINI BUILDS Showcase your Build Talents.
My guide to shaving a yak
Old Jun 16, 2023 | 05:47 PM
  #101
Brad S's Avatar
Brad S
You got a mighty fine metallic BRG R53. I like the chrome mirror caps & your wheels really suit.
Old Jun 17, 2023 | 08:20 AM
  #102
smschriefer's Avatar
smschriefer
Thank you, Brad! I haven't posted as I'm still messing with the wheel speed sensor. I replaced the sensor and I'm still getting the error. I need to swap the rear sensors and see if the issue moves to the other side. Then I can look at the rear bearing and see if the issue is the sensing ring in the hub. There is a lot of grease in the hub and I've read that is fine, but I'm just not sure. I did install new bearings on both side, so I'm kind of perplexed. I just know it is the left rear and I believe that means American drives side rear, or for NZ it would be passenger rear.
Jess Robinson
Dec 14, 2019 12:27 PM
AndyJM
Jun 4, 2019 01:12 PM
-jacob-
Mar 30, 2017 09:30 AM
KandyRedCoi
Mar 8, 2009 08:37 PM
Xymox
MINIs and Minis for Sale (archive)
Oct 23, 2007 12:04 PM
