R50/53 Full Sheet of Plywood in MINI?
Old Apr 26, 2007 | 04:56 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Is it possible to fit a 48x96 sheet of plywood inside of a MINI without a sunroof (preferably with the boot door closed?)
Old Apr 26, 2007 | 05:02 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
No, I do not believe there is enough room without cutting it.
Old Apr 26, 2007 | 05:27 AM
rc'S's Avatar
rc'S
The best way to do that would be to take a Suburban, remove all the name plates, and replace them with MINI name plates. Even a Tahoe is too small to get a full sheet of plywood in and close the boot!
Old Apr 26, 2007 | 06:18 AM
dwjj's Avatar
dwjj
Suburban you have to take out the 3rd seat, fold the 2nd seat completely, then it barely fits. Full length and width of the back.
Won't fit in a mini.
Old Apr 26, 2007 | 06:46 AM
Cherry2005's Avatar
Cherry2005
Here's me with a pocket door frame in my Cabrio, not even as big as the dimensions you gave (36X82). I can't imagine your plywood would fit.
Old Apr 26, 2007 | 10:36 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
I didn't think it'd fit, but I was hoping someone figured out a way to wriggle it in :(. Ahh, all is well, I can handle it flapping out the boot for 2 miles on the way home.
Old Apr 26, 2007 | 10:56 AM
dwjj's Avatar
dwjj
Cut it in to pieces? (sorry...)
Old Apr 26, 2007 | 11:16 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
I'd then have to put it back into one piece, best i could do it cut it down to about 60", technically the width should fit if put in on an angle...maybe
Old Apr 26, 2007 | 03:40 PM
MiniMaxx's Avatar
MiniMaxx
Unless you're a master at cellulose origami...........
Old Apr 26, 2007 | 03:48 PM
Armchairman's Avatar
Armchairman
Old Apr 26, 2007 | 05:23 PM
tigwantstoplay's Avatar
tigwantstoplay
LMAO!
Old Apr 26, 2007 | 06:47 PM
200-OK's Avatar
200-OK
This reminds me of the scene in Men in Black where Edgar is putting his saucer in the back of the Bug-mobile...
Let's just say it didn't quite fit...
Old Apr 26, 2007 | 08:27 PM
minimarks's Avatar
minimarks
In a word...No.
Old Apr 27, 2007 | 02:32 PM
supercliff's Avatar
supercliff
I'm sure you can do it with a mini. I've seen it done with other cars. You just need to know how to load the car properly
http://www.swapmeetdave.com/Humor/Workshop/Overload.htm
Old Apr 27, 2007 | 06:10 PM
jonnieoh's Avatar
jonnieoh
Rent the pick-up truck at Home Depot for an hour. It costs $19.99 per hour, which isn't too shabby.
Old Apr 27, 2007 | 06:39 PM
Cherry2005's Avatar
Cherry2005
Well, since you're only 2 miles away, just walk it home:
http://samplerewards.com/index.cfm?f...roduct_ID=1806
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 26, 2015 01:02 PM
nomar116
Aug 10, 2015 11:24 PM
dchang0
Aug 10, 2015 03:37 PM
SoCalledFriend
Aug 6, 2015 06:59 AM
