Site Feedback Open forum for discussion of this site. Post your kudos or criticism so that we can continually improve service to the new MINI community.
Processing Status?
Old May 19, 2003 | 09:17 AM
Storer's Avatar
Storer
I'm trying to upload pics from the New Milford meet this weekend, but it seems to be stuck on "Processing Status... addding." Any suggestions?
Old May 19, 2003 | 09:38 AM
Mark's Avatar
Mark
North American Motoring :: Founder
Depending on the size and numbers of images you are uploading it could take some time. What type of internet connection are you using? If is is dial-up the connection could have had a hiccup and stalled the upload. If you are on broadband I would expect the upload to complete and not get hung. I believe you should be able to close the upload window and examine the gallery to see if your pictures uploaded. If they did but some don't appear to be complete please let me know and I will delete them. If they didn't upload at all please retry the upload and let me know what message (if any) you receive. Thanks!
Mark
Old May 19, 2003 | 10:37 AM
Storer's Avatar
Storer
Thanks Mark.
The average file size of each pic is about 3 megs (this might be a problem, I'll try saving them as bitmaps instead of jpegs), but I am running on a T-1 connection, so that should not be a problem. I will give it a try again. Thanks
-Chris
Old May 19, 2003 | 10:41 AM
Storer's Avatar
Storer
Guess they have to be jpeg's, got the error message that it can't handle the bitmap format. I'll try again as jpegs.
Old May 19, 2003 | 11:00 AM
Storer's Avatar
Storer
Mark, its been "processing status" for about 10 minutes, just says "adding..."
Old May 19, 2003 | 11:21 AM
Storer's Avatar
Storer
Definintely not working
Old May 19, 2003 | 11:58 AM
Mark's Avatar
Mark
Storer,
Can you tell me what album you attempting to add these images to? Also, the image size of 3MB is very large and could be leading to the hang you are seeing. Given that we typically reduce the image size to 640x480 can you resize them, try uploading these resized versions, and if they don't work please email me a copy of the resized versions (mferguson@northamericanmotoring.com). Thanks and I apologize for the inconvenience you've been experiencing.
Best reagrds,
Mark
Old May 19, 2003 | 12:41 PM
Storer's Avatar
Storer
Hello again Mark,
Actually, I screwed up when I initially stated that the files were appriximately 3 megs, they are actually only about 300 KBs. I am trying to post the pics in the NY/NE Gallery under regional meets. Thanks, and its not a huge problem, just wanted to post some good pics from this weekend's event.
-C
Old May 19, 2003 | 12:55 PM
Mark's Avatar
Mark
In that case can you email them to me? I'd like to see if I can get the same failure. Thanks!
Mark
Oct 19, 2015 08:07 PM
ccfirelt
Oct 18, 2015 01:02 PM
ahorvath
Oct 3, 2015 01:13 AM
Samhillrocks
Sep 29, 2015 12:55 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
