Suspension Rubbing on front FSD struts?
Old Apr 17, 2007 | 07:12 PM
115hp's Avatar
115hp
I recently had IE fixed camber plates installed along with Koni FSDs. I just pulled my wheels off and found some paint rubbed off from the front struts. Any ideas?
Old Apr 18, 2007 | 04:04 AM
satay-ayam's Avatar
satay-ayam
What size wheels and tires are you running?
My first impression is that it probably happened during install.
Edit, actually after a 2nd look, I wonder if the brake line is rubbing the strut.
Old Apr 19, 2007 | 10:55 AM
AntiqueCarNut's Avatar
AntiqueCarNut
I can't figure what would rub the strut in that area. My belief, as well, is that this happened during the installation.
Old Apr 19, 2007 | 04:13 PM
defylogik's Avatar
defylogik
looks like tire rub. but that far down on the strut??
Old Apr 19, 2007 | 08:38 PM
ScottinBend's Avatar
ScottinBend
This is definitely damage from the install.
Old Apr 19, 2007 | 09:10 PM
JustGo4It_'s Avatar
JustGo4It_
Marks from a vise?
Old Apr 20, 2007 | 03:21 AM
115hp's Avatar
115hp
Thanks for the replies! I've had some time to take a better look and the missing paint must have come during installation as there is plenty of clearance (1-2 inches). Also, there was no wear on the inside tires.
Old Apr 20, 2007 | 04:01 AM
daflake's Avatar
daflake
Greg,
If you want to be sure, it might be a good idea to get some tape (like duct) and putting a small piece over the are that is rubbed. Then you can drive for a little bit and check to make fure that nothing is really rubbing as you would see wear on the tape. Just a little test that does work.
Old Apr 20, 2007 | 03:50 PM
115hp's Avatar
115hp
I didn't think of tape, but I actually thought of using a bit of touch-up paint to cover the bare metal. If this did happen during installation, is it customary that they get manhandled?
Old Apr 20, 2007 | 05:03 PM
ScottinBend
No, but they could have dropped the strut while getting it in position.
Old Apr 20, 2007 | 08:43 PM
caminifan's Avatar
caminifan
Edit, actually after a 2nd look, I wonder if the brake line is rubbing the strut. [Emphasis added.]
+1 (on the brake line rubbing the strut where the paint has been rubbed off.) Try some electricians tape (black pvc stuff) over the rubbed area.
Old Apr 21, 2007 | 04:00 AM
satay-ayam's Avatar
satay-ayam
They shouldn't be manhandled like that, but it doesn't mean it doesn't happen. This is part of the reason I usually, begrudgingly, do my own work - most techs at most shops aren't working on the car like they own it.
Old Apr 23, 2007 | 01:16 PM
cboggess's Avatar
cboggess
put some white chalk on the rub mark, go for a drive, pull the wheel off, and see if the chalk transferred to anything that may be rubbing there.
Old Apr 23, 2007 | 02:04 PM
kenchan's Avatar
kenchan
^^ i was going to offer baby powder or flour.
i use to keep a baggie of flour in the garage when i needed to do rubbage
checks on stb's, etc. but it looked too cocaine-ish so i tossed it.
i just go to the kitchen each time. lol
for the scraped area, i too would recommend e-tape or even clear
vinyl packing tape (thick ones).
Old Apr 23, 2007 | 05:30 PM
115hp's Avatar
115hp
Thanks for the suggestions. I put some e-tape on there and will check back in a few days, but I don't expect to find any rubbing. Here's a pic of the clearance with the wheel (16X7, 45 offset) back on:
Old Apr 23, 2007 | 05:36 PM
115hp's Avatar
115hp
Here are two more pictures, now from the bottom of the front struts showing some more missing paint--apparently from the installation.
Attached Thumbnails Rubbing on front FSD struts?-s1.jpg   Rubbing on front FSD struts?-s4.jpg
Old Apr 27, 2007 | 09:45 PM
kenchan's Avatar
kenchan
are the FSD's fitment that tight? or just a careless install?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Emnotek
Aug 13, 2015 05:47 PM
