BACK IN STOCK...12M and 14M GRADE 10.3 TUNER LUGS..Palo Uber Mini.COM
Old Apr 12, 2007 | 09:28 PM
Carol@PaloUberMini.com's Avatar
We are at last back in stock in both 12Mx1.50M (02-06) and 14Mx1.25M sizes. These are the highest quality available on the market, and as far as we are aware, we are still "the only manufacturer in the world" for grade 10.3 fourteen mill by 1.25mill tuner lugs. Both sizes are available in graphite black or nickel chrome.
The primary advantage of utilizing tuner lugs are achieving perfect mating between the wheel and the hub. Using torque wrench application, you know your exact poundage (75-90 ft. lbs.) on each tuner lug. This results in nearly perfect spin when in motion. The use of "high-grade" tuner lugs prevent loose wheels due to track or extreme street performance use. OEM lugs are grade 6.3-6.8, and can easily loosen, resulting in excessive tire wear and alignment problems. Usually without you even being aware of it.
By using tuner lugs, your force during application is exerted directly down wards through the center of the lug by the use of the tuner key. This results in exact and perfect mating of the lug thread to the inner thread of the hub. There is no outside twisting causing extreme fatigue on the hub thread as well as the lug threading, which occurs with "bolt" type lugs and air tools versus torque wrench application.
If your serious about performance, and want the most out of your suspension, tires and peace of mind, you should switch to the tuner lug application. Protect your rims and get the absolute most from your mini.
Go to www.paloubermini.com and scroll through our Online store to find NAM KITS for your NAM only savings. One kit for 12Mx1.50M and one kit for the 14Mx1.25M size. Both sizes in stock and ready to ship, in your choice of graphite black or nickel chrome.
Always feel free to contact our office for assistance in placing your order or for more details....949-725-7983
Numerous detailed photos on our Online store.....many thanks ....Palo Uber Mini London
DixonL2
Apr 13, 2021 08:05 AM
Wohnson89
Jun 10, 2020 04:53 AM
surfblue
Oct 24, 2018 01:20 AM
ShadyCoop
Aug 18, 2015 04:26 PM
ki7hy
Aug 12, 2015 07:07 PM
