Drivetrain Whats so good about the Cometic head gaskets and are OEM ones ok to use.
Old Apr 10, 2007 | 10:05 AM
fozworth's Avatar
fozworth
Im in the process of sticking cp forged pistons in my engine and arp studs ,rod bolts etc.The head is ported and polished and has enlarged valves .The car is running at abput 245/50 bhp at the flywheel.So i wounderd if its worth fitting a cometic head gasket and if indeed it realy is a worth while expence.Or are the bmw oem ones fine to use.
Old Apr 10, 2007 | 10:14 AM
AZMCS's Avatar
AZMCS
I used OEM with copper prep spray. Pushing 200whp now, but will be going to 350+ in a couple of weeks with 30psi. Fireballed runs the OEM with this setup without problems.
Old Apr 10, 2007 | 10:38 AM
fozworth's Avatar
fozworth
ref spray
Whats copper prep spray?
Old Apr 10, 2007 | 02:21 PM
k-huevo's Avatar
k-huevo
The Cometic is a multilayer metal gasket as is the OEM, the main advantage comes when using a larger bore because the Cometic gasket can be made in custom cylinder diameters and thicknesses; the stock gasket come in one bore size and two thickness sizes.
I’m using the Cometic plus ARP head bolts (ARP studs weren’t available then) and there is no coolant in the oil or oil in the coolant after 28,000 miles using a 19% pulley.
Old Apr 10, 2007 | 05:46 PM
AZMCS's Avatar
AZMCS
Sticky copper stuff you spray on the gasket to add in adhesion. You should be able to buy it at any local autoparts store. Just ask them for copper gasket prep.
Makes the gasket look like this:
Old Apr 11, 2007 | 12:55 AM
fozworth's Avatar
fozworth
cheers mate
Old Apr 11, 2007 | 05:24 AM
defylogik's Avatar
defylogik
being from mentor, oh originally, i can vouch for cometic gasket. had a few friends in high school that went on to work there. even one with a pretty fast drag honda sponsored by cometic.
danielbrookes_9
Oct 3, 2015 12:51 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
MIminiclubman
Aug 5, 2015 09:14 PM
kwijmbo
Aug 5, 2015 09:00 PM
