R50/53 oil change question!
Old Apr 8, 2007 | 10:29 AM
tommy_zito's Avatar
tommy_zito
So i was wondering if you take your MINI some were to have your Oil changed will it reset the counter that comes up when you first turn on your car? call me crazy but 15000 miles on one oil change says bad things..let me know!
Old Apr 8, 2007 | 10:50 AM
daflake's Avatar
daflake
You are crazy...
Actually 15000 on todays oils is not far fetched. There is plenty of material on this site and many others for you to draw your own conclusions. This topic has definetly been hashed out a time or two... I'd say use the search function...
Old Apr 8, 2007 | 11:26 AM
ScottinBend's Avatar
ScottinBend
Unless you take it to a MINI dealer the counter WILL NOT be reset. So you could still take it to a dealer for your "free" oil change service. Just be careful where you take the car for the oil change. Most don't recommend the "Jiffy Lube" type of places because of the potential of problems. I am assuming you have an S from your gallery. They are a bit easier to change the oil on. I would suggest you do it yourself just to get an idea on the procedure and it can save you a bit of money.
Old Apr 8, 2007 | 11:28 AM
caminifan's Avatar
caminifan
Personally, unless the factory service program has lapsed, I would not reset the counter. Just keep track of when you changed the oil.
Old Apr 8, 2007 | 02:43 PM
jgf's Avatar
jgf
You can buy a reset service with OBDII from Mini Mania. If your car is under warranty you might go for the service to have other mech. ck's. I drive my S 100 miles per day and while under warranty would chge my own oil and filter every 5000 miles. Today's oil's certainly can last the 15,000 miles, but if you intend to keep as I do beyond 100,000 miles error on the cheap insurance of 5000 mile change. The oil plug is a 13mm and the oil filter is a 36 mm (NAPA or Snap on tool's or Mini Mania). Get a cheap set of ramp's from Walmart etc . and you are in business. It's also a good idea to ck your plug torque as these on the S tend to loosen. Torque setting's are 20 foot pound's. Torque wrench and long extension plug socket approx. 30.00 @ advanced auto part's. Getting to know your car by doing the little thing's gives you additional pleasure 's of ownership. Just my opinion! JGF
Old Apr 8, 2007 | 04:00 PM
Bigcoyote's Avatar
Bigcoyote
I change the oil on my S every 4K-5K miles -- If you take it somewhere be sure to tell them NOT to reset the timer -- that way the dealer will at least pay for an oil service once in a while.
Good luck
Old Apr 8, 2007 | 04:04 PM
muidaq's Avatar
muidaq
You can reset the counter yourself (once you're out of maintenance). http://www.mini2.com/forum/faq.php?f..._faq_reset_cpu
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
serrow
Hawaii
Aug 19, 2015 11:35 AM
danraabe
Aug 18, 2015 09:32 AM
ludedude
Aug 10, 2015 07:16 PM
