R56 Run Flat / Regular Tire Change Out
Old Apr 7, 2007 | 10:02 AM
fredgold52's Avatar
fredgold52
On an 07 MC with the standard rims, can you change the run-flats out to normal tires? Will they fit the rims OK?
Old Apr 7, 2007 | 10:09 AM
Robin Casady's Avatar
Robin Casady
That is what people are saying in the general wheel and tire section. You can go from runflat to normal tires with the factory wheels. What you can't do is put runflats on a wheel that is not designed for them.
Old Apr 7, 2007 | 10:14 AM
fredgold52's Avatar
fredgold52
Thanks Robin.
Old Apr 7, 2007 | 11:34 AM
amazonracer's Avatar
amazonracer
Can I opt out of the run flats from the factor if I order the r56
Old Apr 7, 2007 | 12:08 PM
Robin Casady
Depends on whether you are getting the S or not. MINIUSA.com shows that the MC comes with standard tires and a spare. It is the MCS that doesn't have room for a spare, so it only comes with runflats.
You could ask your dealer. They may be willing to do some deal with swapping the runflats for something else.
Old Apr 7, 2007 | 02:03 PM
MINIAC's Avatar
MINIAC
15" wheels come with conventional tires and all larger sizes come with run flats.
Old Apr 7, 2007 | 06:50 PM
Robin Casady
On which model, MC or MCS?
Old Apr 7, 2007 | 06:53 PM
MINIAC's Avatar
MINIAC
15" wheels are not available on the MCS, but run flats apply to larger wheels on both models.
davidbeaver1
14
Nov 8, 2015 05:22 AM
Powershift
Aug 16, 2015 05:14 PM
FLYM1N1
Aug 16, 2015 01:17 PM
sabjcw
Aug 14, 2015 07:40 AM
