Suspension How does one fix too much camber/castor ?
Old Apr 7, 2007 | 07:28 AM
PortMCS's Avatar
PortMCS
Im thinking a good alignment will do it. OR do i need to install adjustable end-links and or control arms ? Should i do that in addition to the alignment or is this optional ? Eventually im thinking of doing the rear swaybar and if need be, i can do both at the same time.
My rear wheels seem to be "tilted" and i would like to straighten them out to match the fronts, especially since i just installed new wheels and tires last week, i dont want the tire wear to be off.
Any help appreciated !!!
Vic
Old Apr 7, 2007 | 07:30 AM
mbcoops's Avatar
mbcoops
Get an alignment. If you want to go beyond the stock allowable settings, then you need camber plates up front and lower control arms in the rear.
mb
Old Apr 7, 2007 | 10:58 AM
ScottinBend's Avatar
ScottinBend
The rear wheels have much more camber stock than the fronts. The "tilt" is normal. You shouldn't see any additional wear because of it.
Old Apr 8, 2007 | 02:12 AM
PortMCS's Avatar
PortMCS
^ Really ? It just bothers my eyes i guess, especially standing behind the car. Thanks for th info guys !
Hey mbcoops, whereabouts in NJ are you ? I just moved down here to the Union area. I guess theres more than one Dinan S1 around here! lol
Old Apr 8, 2007 | 05:51 AM
snid's Avatar
snid
If your car is lowered, it will increase the negative camber in the rear. Early cars have no adjustment for camber in the rear. Later cars have a little. If you're lowered an inch or more, you'll probably need a set of adjustable rear control arms to remove some of the negative camber in the rear.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
minimofo
Dec 26, 2015 12:03 PM
gnhovis
Dec 14, 2015 05:31 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
