R50/53 Door Rattles and Roof Material Squeeking Noises
Old May 15, 2003 | 05:23 AM
Swifty's Avatar
Swifty
Doors Rattles i.e. movement sound. I have had the door seal relaced but ot no avail - seemed to make it worse. Now the roof meterials makes a foams crackling sound. Also like many others have the seat belt adjusted problem. Have had the major sunroof problem temp fixes i.e. velcro on flaps for tilted rattle, rubber stickon for closed roof rattle.
Please help if you know the answer to the other ones. I appologize if I am repeated others queries. Your Aussie Mate.
Old May 15, 2003 | 06:18 AM
fins4284's Avatar
fins4284
Is it a rattle or buzz near the lock and reflector area? If so, pull the door panel and wrap the rod which attaches to the lock **** with some electrical tape. While you're at it, go ahead and cover the female receptacles of the door with electrical tape where the plastic pins insert. Also place tape underneath the styrofoam incase the day to day vibrations causes the buzzing sound. That should solve your problem. Did mine. Good luck!
_________________
I'm growing older but not up. My metabolic rate is pleasantly stuck - J. Buffett
Old May 15, 2003 | 07:51 AM
sambusik's Avatar
sambusik
fins4284,
was your rattle coming from the passenger door? I have a rattle/buzzing from that area, but I can't figure out whether it's from the glove compartment or from the passenger door.
gonna have to do some snooping
Old May 15, 2003 | 03:36 PM
fins4284's Avatar
fins4284
can't help you if it's the glove box. i had same rattle/buzz on both doors. same mechanicals. so if it is your pasenger door, i'd try the fixxes previously mentioned. good luck...
Old May 19, 2003 | 06:57 PM
Swifty's Avatar
Swifty
Thanks Fins4284 and Sambusik. Most of my noises seems to sound like the top of window moving on the door seal thus getting seal squeeking mvement noises - very irratating. I thought they had gone away but found out that my tire pressures were very low -thus making the ride softer. Both doors seem to have the problem - maybe electrical tape may help. The dealer is now plastic coating the boot door latch to stop the metal rattle in there. ANyone no the fix for what appears to be the seat belt adjuster?
Thanks again.
Swifty
Old May 19, 2003 | 07:05 PM
fins4284's Avatar
fins4284
Swifty,
Have the dealer realign your windows. Worth a try. Electrical tape is not a long term fix. Good luck...
Old May 23, 2003 | 12:37 PM
andrew's Avatar
andrew
My dealer added insulation to the inside of my driver's door and it eliminated the noise.....I was told it is a "common" rattle with MINIs.....rattle gone...bugged me for about a year.....right in my ear !! :smile:
Old Jun 3, 2003 | 04:20 PM
rembrandt's Avatar
rembrandt
I have a 02 cooper with a rattling noise from the rear hatch door. What can be done to silence it?
Melvinyip
Apr 17, 2020 09:28 AM
woodstudio
Mar 15, 2020 08:28 AM
Dec 23, 2015 10:36 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
