Hamann HM4's with factory run flats?
Old Apr 5, 2007 | 07:53 AM
Trip024's Avatar
Trip024
Hi Guys,
Im planning to purchase the Hamann HM4's 17x8 in the next couple of weeks but before I take the plunge I need to know if these rims would work w/ the factory run flats I have right now. If not what would be the best tires (brand/size) to do the job.
Thanks for your help
Old Apr 5, 2007 | 04:08 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by Trip024
Hi Guys,
Stock rims are 17x7 and 205/45-17 tires normally are designed to fit rims 6.5 to 7.5" wide. You can stretch that tire on a 17x8 rim but it's better to use a tire that was designed for the wider 8" rim for best effect.
If you just want to wear out your runflats then yes you can mount them and use them up.
When you replace them you can look at other runflats in the same size if you want the runflats- consider the less costly
Kumho ecsta SPT XRP $133 but it weighs a hefty 28 pounds!
or since you are in So cal you can use Ultra High perf Summer or All season tires like
Michelin Pilot Exalto PE2 in
215/40-17 $151 fits rims 7-8.5" wide 20 lbs. 23.8" outer tire diam.
215/45-17 $168 fits rims 7-8" wide 22 lbs. 24.6" outer tire diam.
240 treadwear A traction W speed rated
Or in the same tire class
Firestone Firehawk Wide Oval
215/45-17 for $125 each
320 treadwear AA traction W speed rated 22 lbs.
Contact Alex@tirerack.com for more info on your options
Old Apr 5, 2007 | 06:46 PM
Trip024's Avatar
Trip024
Thanks Minihune,
Most probably I will use the factory runflats until they run out. Once they do run out between the 215/45 and 215/40, which of the two provides a more comfortable ride. Assuming I do away w/ the run flats.
Old Apr 5, 2007 | 08:15 PM
minihune's Avatar
minihune
Thanks Minihune,
For the track it is common to wear out tires very quickly due to lack of front camber. Be careful and easy on your tires.
45 series tires will be more comfortable than the stiffer sidewalled 40 series tire. 215/45-17 would work for street use.
Old Apr 5, 2007 | 08:28 PM
BLKDINAN's Avatar
BLKDINAN
Minihune has said it all. I'm using 215/40 Eagle F1 GS D3. Even thought I have the DINAN S2 suspension, I definately noticed a softer rid on my higher profile winter snows on MINI rims.
Old Apr 5, 2007 | 08:45 PM
Wake|MCS's Avatar
Wake|MCS
Ehh I'll take 215/40/17 over 215/45/17 ANY day of the week. The look is SOOO much nicer. As for tires, I'll personally be going with KDW's once my Ziex wear out...
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
