R52 No beading drops after Ragtop?
It finally :impatient rained on my top for the first time since I did the Raggtop cleaning and treatment weekend before last. I expected the water to bead up, but it looks the same as it did before the treatment.
Did I not put enough RT on it?
Judging from this http://autopia.org/forum/guide-detai...-top-care.html, it appears that the water should bead.
Apparently I did not apply the protectant properly, but I don't know what I did wrong.
Well, I do know I ran out of time and didn't do a 3rd coat
, but it's hard to believe that
2 coats = no bead
3 coats = beads up
, but it's hard to believe that 2 coats = no bead
3 coats = beads up
I'm also curious about how much raggtop it takes to bead. I've seen a top with raggtop bead the water beautifully, but after my detailer put raggtop on I didn't see any beading and just assumed that he didn't do it or put on too little.
I think the beading has to do with the type of water being thrown down onto the roof. There will be days in complete downpours where my roof doesn't bead, then there will be the "light" rains that will bead and slide right off (usually on my head as I'm sitting down). I think I last applied 303 in November 06 and I still get beads. We're not quite done with winter here in Ohio, so I'm guessing it'll be a few more weeks before I can. Then again, it's going into the dealer tomorrow and I might bring up the wear marks on the hood (above the rear windows) and see if they might be good enough to write it up for replacement..
After I use raggtopp mine beads like crazy (moreso than with 303). I think it's best to apply the protectant in full, hot sun where it almost dries off right when you apply it (if that helps)
I have experienced heavy beading when I used Raggtop and it lasts quite a long time. The one thing that would lessen its effect is if you spray it on while the top is still damp. It needs to be pretty much bone dry or the spray won't set right and you won't see the beading.
I have the Raggtopp kit here at the house, I'm just waiting for the weather to stay consistently warm and sunny for a few days in a row before treating the tops on our MINIs.
Thanks for all the input. It could have been that it was still damp down deep. I think another significant factor was that there was a breeze and I was trying to follow the directions about how far away to be. I think most of it blew away.
Doh!
Friday night I vacuumed and lint-rolled it good and clean. Saturday morning, I masked off the glass & paint areas, and put the rest of the can (2 1/2 more coats) on from about 9" away. When ever I felt a breeze, I paused until it was gone. Later in the day, when I washed him, it beaded.
Doh!Friday night I vacuumed and lint-rolled it good and clean. Saturday morning, I masked off the glass & paint areas, and put the rest of the can (2 1/2 more coats) on from about 9" away. When ever I felt a breeze, I paused until it was gone. Later in the day, when I washed him, it beaded.
It's not "widely available" in the sense that your local Pep Boys or Autozone will carry it, but it's available from a bunch of places online. I got mine at Detailer's Paradise, since I'm always ordering stuff from there anyway.
If you do a web search for it, remember that it's "Raggtopp" (two g's, two p's).
You mentioned you had some problems with the wind on the first application. If I treat the cars in the garage, away from any breezes, do you think I'd be able to cover both tops with three coats from a single can of protectant?
I am hoping it will be warm enough this Friday so I can try a new paint-on product called Renovo Ultra Proofer that I got from Detailer's Paradise. I know the application may take a smidge longer but not having to tape off or worry about overspray or the wind blowing away the spray has made me wanna try this stuff. I will let you guys know how it works
Well, I guess I don't have to treat this top with any care... A new on is on order.
Riquiscott, you MIGHT get 6 coats from one can. My interpretation of a coat is pretty liberal. I went over all seams a second time.
I can't use Raggtop in my garage. There are 2 gas appliances - WH & furnace. Can says "extremely flammable". Don't want to blow up.
Bamatt, good luck with the RUP paint-on. It would be nice if that works.
ThomB, can you take/post pics of the wear-marks that netted you a new top?
I'll try. I think it's pretty funny. The marks (I believe have been referred to as "white marks") are above and slightly behind the rear windows. It appears that they are caused by the sub frame. It's like the material is rubbed off a bit on the exterior of the top and to me (only from a certain angle) it shines when the light hits it just right.
Not wanting to start the top waterproofing flame war..
But I'm still LOVING my 303 treated roof - almost 6 months later, it beads like CRAZY and nothing seems to stick to it. Looks like new, after probably 80+ open/close cycles...
Maybe it will get worse and start to bother me more.
I'll go try to get a photo of the area now...
I think localized "shiny spots" are going to be an inevitable result of folding the top up and down repeatedly. Both of ours have them, but the cloth isn't worn or frayed anywhere. I've seen other tops where the cloth actually begins to get thin and wear through.
Here is a photo. I've put 3 images in my gallery. this image in it's full blown size also shows the material quite clearly. (Don't mind the dirty windows, Winter's back in Northeast Ohio.)
From what I've read on different threads, the wear marks are the result of rubbing when the top is down and being bounced around while driving (i.e. not from putting the top up and down).
When I sprayed Raggtop on the roof, it seemed to sit as tiny droplets on the surface of the fabric. I rubbed it down to work the Raggtop into the fabric, using a hand in a plastic bag. Not sure if this is a good technique, but beading did last a long time.
https://www.northamericanmotoring.co...1_no_flash.jpg
I have an 06 with the same marks and live in the same climate as you. Drove mine all winter and am surprised how well the top weathered. I'm not worried about them as they seem like pressure points that mat down the fabric (look like shiny spots) and don't seem to get any worse. I'm surprised that the dealer would replace a top for this unless you are one of the unlucky early 05 owners that are covered by the service bulletin for truly excessive wear. If I were you I would drive it and wait until the warranty is about up and then have it replaced. I gaurantee the same marks will reappear if you get a new roof. Just the nature of the design. Clean it and treat it with Raggtop once the weather breaks and they'll practically disappear.
