Drivetrain Oxygen Sensor Plug Location
Old Apr 4, 2007 | 08:22 AM
gnhovis's Avatar
gnhovis
Reverse
Where does the after-cat O2 sensor plug in? Do you get to it from below or from the engine compartment? I may have damaged the wire when I removed the exhaust and I want to check that it's still seated. Thanks.
Old Apr 4, 2007 | 09:08 AM
jgf's Avatar
jgf
R-53 Cooper S - Plugs into the driver's side rear of cat, wire's go into engine bay to thr right side of the header's. Easy to reach from below
Old Apr 4, 2007 | 11:52 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The post-cat sensor plugs into a connector under the car, partially hidden by the heat shield. The pre-cat sensor plugs into a connector near the left side (of the car) of the head, between the head and airbox.
silence2-38554
98
Sep 21, 2016 02:52 PM
dscott90000
Aug 21, 2015 07:07 PM
Aug 19, 2015 12:51 PM
Dashdog
Aug 10, 2015 06:17 AM
joelcseymour
Aug 7, 2015 12:43 PM
