Drivetrain Oxygen Sensor Plug Location
Where does the after-cat O2 sensor plug in? Do you get to it from below or from the engine compartment? I may have damaged the wire when I removed the exhaust and I want to check that it's still seated. Thanks.
The post-cat sensor plugs into a connector under the car, partially hidden by the heat shield. The pre-cat sensor plugs into a connector near the left side (of the car) of the head, between the head and airbox.
silence2-38554
98
Sep 21, 2016 02:52 PM
dscott90000
Aug 21, 2015 07:07 PM
Aug 19, 2015 12:51 PM
