16" S-Winder weight revealed!
Old Apr 3, 2007 | 08:37 PM
MotorMouth's Avatar
MotorMouth
I'm putting some Avon tech RA 215/40r16s on a set of S-winders and I made SURE I had a scale available to weigh the rims since nobody seemed to know how much they weigh.
well - here is the definitive answer! (and it's pretty good!)
Old Apr 3, 2007 | 09:00 PM
MotorMouth's Avatar
MotorMouth
and for the curious -
215/40r16 - 22 3/4" tall vs stock 195/55r16 - 24 1/8" tall. I wonder what that'll do to the gearing.
Old Apr 3, 2007 | 10:34 PM
ohs68's Avatar
ohs68
Well, the engine speed at any given road speed will increase by the ratio of the OEM tire diameter divided by the new tire diameter.
Alan
Old Apr 3, 2007 | 11:27 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Smaller than stock outer tire diameter will mean lowered gearing but if your gearing is not tall then you get to use more of 2nd gear and even consider 3rd if you can drive fast enough. This is not bad.
Can you re-weigh the whole wheel- tire and rim and see what you get.
215/40-16 Avon Tech Ra should weigh ? pounds - it's not even listed at tirerack in that size!
16.625 lbs for the rim plus ?pounds for the tire =? pounds estimated.
Old Apr 3, 2007 | 11:37 PM
MotorMouth's Avatar
MotorMouth
WOW! It did say low stock/closeout when I ordered from there. I guess I got the last 4.
I'll weigh them tomorrow and see what I get. Gotta be sure to subtract 40lbs of air though!
Minihune, you gonna be at Aloha Stadium easter sunday? I plan on getting there early and trying to be a walk-on. I couldn't pre-register online since I haven't autocrossed before. Hopefully, since it is Easter I'll have a chance of getting to race. My MINI will be eligible even if I don't get signed up because Randy is going to run it (GS of course). oh yea, got a spare helmet?
Old Apr 4, 2007 | 02:38 AM
Krut's Avatar
Krut
That's great news - those are some LIGHT wheels!
Old Apr 4, 2007 | 04:30 PM
MotorMouth's Avatar
MotorMouth
Weight including rubber and 40psi of air is 39lbs 13oz.
Old Sep 26, 2007 | 11:00 PM
minihune's Avatar
minihune
Thanks for the total weight.
For comparison
15" stock Holey rim with stock Conti 175/65-15 tire 28 lbs
15x7 Kosei K1 TS with Kumho V710 205/50-15 tire 30.4 lbs
949Racing 6UL 15x8 rim with Hoosier A6 225/45-15 tire 32.6 lbs
Centerline RPM 17x7 rim with Bridgestone Potenza S-03 215/45-17 38.2 lbs
Old Sep 27, 2007 | 05:49 AM
Dan00Hawk's Avatar
Dan00Hawk
This shows them at 17.4 lbs:
http://www.mini2.com/forum/faq.php?f...factory_wheels
No way to know which scale is more accurate, but it at least confirms they are around the 17 lb range and a decent choice for a factory wheel for the track.
Old Sep 27, 2007 | 08:05 AM
minihune's Avatar
minihune
We know that the scale used by motormouth is accurate and the picture of the reading is posted above. Not sure why the weight listed on MINI2.com is 17.4 but it used to be 22 lbs before the S-Winder was weighed and this post was made.
Find the same rim and weigh it yourself. See what you get.
Old Sep 27, 2007 | 07:08 PM
Dan00Hawk's Avatar
Dan00Hawk
I'm not up for the "challenge" of finding a random wheel just to weigh it. Just posting that contradictory information is listed on the other site. Maybe the moon was closer to the earth during the weighing or it was done on one of the poles resulting in the discrepancy.
Old Sep 27, 2007 | 07:50 PM
kenchan's Avatar
kenchan
when was that scale last calibrated?
freeman727
Dec 10, 2017 04:00 AM
danielmini
Oct 20, 2015 02:09 PM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
