Suspension Wilwood Big Brake sensor problem
Old Apr 2, 2007 | 04:44 PM
pberd's Avatar
pberd
Hi all;
I installed those cool red Wilwood big breaks on my '06-S and I can really feel the stopping power. Can anyone tell me how to shut off or overide the annoying yellow warning idiot light on the speedo that is trying to tell me my pads are worn. Thanks for your help.
Old Apr 2, 2007 | 10:53 PM
1nf3rn0's Avatar
1nf3rn0
You just need to complete the circuit of the sensor. Take the OEM sensor and cut it about 6" away from the wear point. Strip the wires (theres 2 of them, and they're tiny!) and sodder them together. Wrap them with electrical tape and tuck it away somewhere where it won;t get torn up. Drive your car around for a while and the light should shut off.
Hope that helps!
Originally Posted by pberd
Hi all;
Old Apr 3, 2007 | 05:28 AM
meb's Avatar
meb
...or have the dealer shut the light off. That's what I did.
Old Apr 3, 2007 | 10:26 AM
1nf3rn0's Avatar
1nf3rn0
Don't they charge for this though? The solution i talked about is simple and costs almost nothing....
Old Apr 3, 2007 | 11:53 AM
pberd's Avatar
pberd
Thanks "Inf3rno" I will get it done this weekend
Old Apr 3, 2007 | 11:58 AM
quikmni's Avatar
quikmni
Had your warning light been on before the switch to Wilwoods? Otherwise the light should not be on and the sensor can just be secured out of the way. Once the sensor is worn out and the light comes on, than you must reconnect the two leads in some way. As suggested you can cut the lead and solder the two wires together or you might be able to remake the connection at the sensor. For example, solder a wire between the two wires to mimic the original sensor configuration (before being worn-through).
Old Apr 3, 2007 | 01:38 PM
1nf3rn0's Avatar
1nf3rn0
I had thought of that too. The problem with it is that the connection on the wear sensor can be broken when you remove it from the brake (this happened to me). It sensor is also fragine enough that it could break once its tucked away. The somultion I talked about has the least likleyhood of breaking in the future. I look at it like this: Spend 5 minutes now to make it so you don't have to worry about it ever again, or have it break in the future and spend a long time trying to figure out what went wrong....
pberd: Anytime
Old Apr 3, 2007 | 02:35 PM
meb's Avatar
meb
I wasn't charged, but BMW have a reputation for charging an hours labor to diagnose a light problem. So, he may be charged.
Your fix is a good one and inexspensive
Kimolaoha
Jul 5, 2023 01:04 PM
Toolman
Jan 20, 2016 06:50 AM
elightbo
Aug 17, 2015 01:50 PM
massmini03
Aug 12, 2015 11:19 AM
