R56 Upper Storage Box(Some notes to help other)
Old Apr 2, 2007 | 06:30 AM
bigcat4275's Avatar
bigcat4275
Hi All,
Received delivery of my 2007 Cooper S with Ipod adapter installed on Thursday.
By Sunday I was dying to know what was in the hidden compartment. Saw what looked like velcro holding the door down so I gently pried on the door with a screw driver and viola!!!!!!!!! Door popped open and however in the process I broke the locking mechanism :(. Dealer had done the install on the Ipod adaper and they put some black putty around the edge of the door which I assume was to prevent the door from being pressed in to release the locking mechanism to open the door. Once I had the door opened I removed the 2 black trim covers on either side of the box, the 3 screws under the trim piece with the lower glove box button and the assorted screws holding the upper storage box in place. Once I reomved the box I noted that I must have knocked some pieces off because I could operated the door but once locked no matter how much I tried I was unable to get the door to release again. My assumptions are if you have the black putty try heating with a hair dryer to allow the putty to soften and then try pressing in firmly. Prying is not the answer . Also the service guy showed me a piece of paper that says once you have the Ipod adapter installed they are supposed to keep the upper area locked so you do not have access to the unit. There is enough room left over inside that area for the adapter and my ipod so I am going to try and order just the box and reinstall myself if I can. if this does not make sense or if anyone wants further clarification ask away and I will try to help.
Old Apr 2, 2007 | 06:40 AM
Loony2N's Avatar
Loony2N
The thing that doesn't make sense is that MINI is unable to fix a rattle on a storage box mechanism. Good thing the doors don't rattle, or they'd have us climbing in the boot! Come on! Is this thing really made by BMW?????
Old Apr 2, 2007 | 06:48 AM
DyeLooper's Avatar
DyeLooper
Picked up my MCS on 3/24/07-My compartment opens freely and does not rattle.
Old Apr 2, 2007 | 06:52 AM
Loony2N's Avatar
Loony2N
Cool! I'm still hoping, DyeLooper. Mine should be here in about 3 weeks.
Old Apr 2, 2007 | 07:33 AM
cymrusteve's Avatar
cymrusteve
Same here. Picked mine up 3/29/07. My MA said it was glued shut but would probably be the first recall announced for the R56. I didn't try to open it that evening, but the following morning pressed firmly on either side of the door........and up it popped!
Let my MA know and he said it looks like they've added 2 larger foam circles to stop the rattling...
Old Apr 2, 2007 | 07:34 AM
lava's Avatar
lava
So you are saying that the cars that have the compartment door locked, it is held locked with velco and black "putty" Can you give us a photo showing where the velcro was located, and where the putty was. I have a feeling that if I knew where this was I could dislodge it with a an "L" shaped piece of wire rod.
Old Apr 2, 2007 | 08:42 AM
bigcat4275's Avatar
bigcat4275
The sheet I have says the installers should put velcro. There was no velcro only the black putty. If you are sitting in the passenger seat on the left side by the air vent there was a larege gob on the door and then smaller pieces of the black stuff all around. The wire loop is a good idea.
Old Apr 2, 2007 | 11:27 AM
benfica09's Avatar
benfica09
picked up my MCS on Friday, and the hidden compartment opened up just fine.
one of the first things I checked.
Old Apr 2, 2007 | 11:30 AM
aznqtboy984's Avatar
aznqtboy984
According to my MA, the secret compartment issue is resolved. I picked up my MINI last week and it opens nicely.
Old Apr 2, 2007 | 11:32 AM
Beached1's Avatar
Beached1
I picked up my MCS on March 17th. My compartment opens and does not rattle.
Old Apr 2, 2007 | 12:14 PM
Loony2N's Avatar
Loony2N
Looks like I am going to have to buy some useful accessories to go in there!
Old Apr 2, 2007 | 12:19 PM
07PepperS's Avatar
07PepperS
can you shoot a pic pls. . thx
Old Apr 2, 2007 | 12:32 PM
Böhme417's Avatar
Böhme417
I picked up my Cooper on 3/31, and they compartment opens. My MA said they just started re-opening the ones they had.
Old Apr 2, 2007 | 01:01 PM
dchautin's Avatar
dchautin
mine opens and doesn't rattle either..it's fine. I like it.
Old Apr 2, 2007 | 01:15 PM
daffodildeb's Avatar
daffodildeb
I just emailed my MA about this, and the response was this technical service bulletin from MINI:
Topic: Dash Storage/CD Changer Compartment
STATUS: As of 1/31/07 the dash storage/cd changer compartment has been installed 100% at the plant.
Correction: A retrofit procedure will be issued in a service information bulletin when the required parts are available
Looks like we early birds (I'm week 3) are the only ones with the problem!
Old Apr 2, 2007 | 01:18 PM
muidaq's Avatar
muidaq
If I bought off the lot, how do I find out what my build date was? Mine doesn't open either.
Loony2N's Avatar
Loony2N
Not that simple, daff. In a prior thread where I asked about it, some got it open, some got it sealed. Some were told it will be open when there is a fix and some were told it won't be. It has only been today that it seems everyone is saying they are getting theirs open. I sure hope mine is.
Old Apr 2, 2007 | 01:27 PM
JohnBLZ's Avatar
JohnBLZ
Can't wait to have mine open...
Old Apr 2, 2007 | 02:27 PM
ejkd's Avatar
ejkd
Same here!
Old Apr 2, 2007 | 08:22 PM
lava's Avatar
lava
I can see the edge of some velcro tape at the right bottom. Its not sticking out into the gap anywhere else that I can see. Its stuck down good! I tried prying up on it, but it does not feel like its going to let go without a fight.
Old Apr 2, 2007 | 09:13 PM
JohnBLZ's Avatar
JohnBLZ
Mine is stuck down tighter than a ....well nevermind the not so clean analogy...
Really wishing MINI would hurry up and get this fix out there.
Old Apr 2, 2007 | 10:12 PM
designerMINI's Avatar
designerMINI
I had my MINI in for bonnet stripe installation today and asked about the compartment. I was told that the only MINIs that will have the doors unstuck will be those that order the CD changer or the ipod adapter. That seems rediculous. If cars are being delivered with them opening today regardless of whether they have either accessory why would such a feature be denied anyone that ordered the cars earlier. Especially since it was locked down as a result of a defect.
This service tech must be wrong, right? It's seems completely dumb otherwise. -- rant over :impatient
Old Apr 2, 2007 | 10:23 PM
daffodildeb
Lynn--this was the word as of today's advisory--direct from MINI.
Old Apr 3, 2007 | 03:56 AM
Loony2N's Avatar
Loony2N
I'm glad to hear that, daffodil. Of course, my MA said they got their info from MINI, to. But I have my doubts.
Old Apr 3, 2007 | 11:15 AM
lava's Avatar
lava
Deb - do you think your dealer would be so kind as to give you a copy of that official correspondence? If you could scan it and post it then people like designer whose dealer is hoping he will give up will have some leverage for getting his storage door fixed.
