Drivetrain R56... Where's the SC pulley go???
Old Mar 30, 2007 | 01:43 PM
ALTA2's Avatar
ALTA2
Manufacturer
R56 Dyno Time
Where Does the SC pulley go???
Well as many of you know we have had our new 07 Mini Cooper S for a few weeks now. In those few weeks many new items have been developed. Many, mimicking parts we offer for the Supercharged cars. Even a “Supercharger Pulley” type of part for the R56 is in the works. If there was a way to let only our customers read this and not our competitors, we would, but hey, this info will help educate our future R56 customers and hopefully get them to buy our parts!
Lets start with what kind of power the R56 makes. According to Mini USA, the new car is supposed to make 172 horsepower, with 177 pound-feet of torque, up 4hp, and 22ft-lbs. Like other dyno runs we have done in the past, we started with a Dynopack Dyno. On the scale of high and low reading dynos, its right in the middle, so results will not be skewed one way or the other. We spent a lot of time setting up the dyno so results would be more accurate and consistent. Start RPM had to be adjusted because the car built boost so quick, as well as other things. But once we were all set, it was time to do a run. For the fans we used 2 big fans and the hood closed. Both positioned about 2ft from the bumper. Lastly one of the parameters we messed with was the start RPM. Because this car build boost instantly, too high a number resulted in 14psi of boost just sitting there when the dyno launches. We ended up with 1300 RPM, where the car would build about 4psi of boost before the dyno let it go. This instant response is why small turbos can be a good thing.
Hmmmm, something doesn’t seem right here. We were making more power and more torque at the wheels than the engine was rated for. We checked to make sure the setting were correct, and they were. So why is the power so high?? We have our theories, but that is all to be discussed some other time. Sport mode did nothing but improve throttle response, the boost level, and boost consistency was the same. But boost consistency played a big part in consistent power. There seemed to be 2 different boost curves we would see. The most common was a peak of 15psi, dropping to 13psi, then back to 16psi, then dropping off to 12psi. A big roller coaster! Then about every third run, we would see a very low boost curve. Peaking at 11psi, dropping to about 9psi, then climbing to 14psi, then back down to 10psi. Because we were logging everything going on in the car, there was nothing we really saw that caused this. Even on the road we noticed these strange occurrences. So needless to say, during the testing, all the “Low boost” runs were removed and not accounted for.
INTAKE SYSTEM TESTING BEGINS……….
Our initial test of the intake system was done with the OEM hood scoop left in place. Our intake is designed to remove this, but we wanted to prove how this was a necessary mod. So we did 3 quick runs with the scoop on and 4 quick runs with the scoop off. Below are the runs, with the strange low boost runs removed. The dyno’s runs are redrawn over with a wide brush to show the average of the 2 runs. With no scoop, the filter temps constantly climbed. In 3 quick (10 second interval) runs, the temps were at 150 degrees. With the scoop removed, an instant 30F drop occurred, and a constantly cooling temp change started. The next 3 quick runs showed a nice change in both temp and Wheel HP. The gain was somewhat expected, and the scoop needed to be removed to get the most from the intake system.
Above graph shows averaged runs with and with the scoop being blocked.
So where is the “complete” cold air intake?? The feasibility for a cold air intake is never out of the question, but the cost is the issue here. We wanted to bring the best bang for the buck to the plate first, not scare people away. Since our intake did so well in its form you see here we will continue with developing it this way. Plus we have some things up our sleeves to make it even better.
On a side note, when dealing with MAF (Mass Air Flow) sensors, small changes to turbulence in the intake system, can make huge changes to how the car runs. Because we are familiar with this problem on other cars, great care was taken to eliminate any turbulence issues that might throw a CEL, or make the car run too lean or rich. We can say for a fact that our intake replicates the stock MAF curve nearly perfectly!
Above graph shows averaged runs with and with the scoop opened up and intake installed!
Next up, the Cat-back exhaust….
For all these tests we started with the car being bone stock. So the OEM intake went back on. The catback exhaust is comprised of just that, an exhaust that starts after the cat(s). Yes there are 2 cats on these cars! This part is what we feel is going to be the most popular part to install, because of the sound and HP gains, and legality of it. The legality comes from the fact that it isn’t a part the CARB cares about, and it doesn’t mess with EPA issues. The only thing that the catback will have issues with is noise, and we will be far under any states maximum decibel level.
The ALTA 3” Catback is comprised of 3”OD,18g 304SS tubing, with V-band connections where needed. V- band connections provide a leak free, gasket less connection, that allows for rotation of the 2 joints. The look of the muffler section we wanted to keep similar to stock, but more beefy. With the larger round dual wall, twin tips, and polished can, I think we make it as perfect as we could. The sound of the catback is very mellow and not much louder than the OEM system. The OEM Exhaust is made from 2.166 or 55mm OD tubing, so needless to say, its small for a turbo car. So how do we connect the catback to the small OEM system? With a small adapter! Behind the last cat, you simply cut the exhaust, and slip our system on! Simple job anyone with a hack saw can do. With all these features at a reasonable price, it will be hard to beat what we are offering.
On to the test. Like our other parts, we did many runs to prove the gains were not a fluke. After our 7 or so runs we saw a great average gain of 10WHP and 10ft-lbs of torque above 4500 RPM. The only thing we plan on changing is the sound. In catback form, it is almost too quiet. So, a slight muffler change for a slightly louder sound and we are done. Because of how quite this is, look for 2 different versions one louder than the other.
Above graph shows averaged runs with the 3" ALTA catback installed.
TURBO BACK TIME!
Next up was the turbo back exhaust. The turbo back exhaust consists of the same basic parts as in the cat back, add a 3” mid section with CARB legal cat, and a downpipe with another CARB legal cat. The complete turbo back system is 3” everywhere, but the first 8” are 2.5” tubing to make the turbo connection and gain clearance around the header. One of the most important features is that the OEM heat shields fit over the downpipe. This we feel is very important as the turbo sits so close to the hood.
Onto the dyno test. Like the catback by itself adding the downpipe and midpipe netted very good gains. We gained more than 20WHP and 20ft-lbs which is awesome considering the car still runs the same boost levels during these runs. Besides the HP we gained during the runs, one thing we noticed was while the car was in its holding pattern on the dyno, it was getting 7psi of boost now, not the 4-5. This is also seen on the graphs by the huge 40ft-lbs gained at 2000 rpm! So another important thing to take note of! This would definitely be noticeable on the road at low rpm. Sure enough, on the freeway cruising around, we get nearly instant boost response.
We are setting the standard from which others will be judged from. Yes another company has an R56 exhaust out, but its 2.5” and they never did a before HP run. So they claim it makes 27HP because they made 202 at the engine, and since the stock car is supposed to make 175, it must make 27HP. Not very good proof IMHO.
Above graph shows averaged runs with the 3" ALTA Turboback installed.
FMIC TIME!!
Finally Mini put a front mounted intercooler on this car! Compared to the R53 intercooler, the size of the R56 IC is bigger and much better place. But once again Mini could have done a little better. First off half the IC sits under the bumper. This is not good! So one of the first non-obvious parts we made and tested was an IC diverter.
A simple but optimally sized plate that diverts the air down to the IC. We did all of our tests above with out this to make the results more “real world”. But our initial tests showed a pretty noticeable change in air temp, and IC temp recovery. First off, the first 4 runs, the post IC temps would go to about 150-151 at the end of the run. Between runs we had about a 40 seconds of recovery, which post IC temps would drop to 129-130. With the diverter installed, we saw a solid 6-7degrees of drop! This is only with a single fan in the front of the car, definitely not a good representation of air flow you might see on the road. So the potential for this to be a good inexpensive mod once on the road is proven with minimal air flow.
Now to our first FMIC prototype. Using the “no IC is too big” theory, which works 90% of the time, we set out to build 2 different styles of IC’s, but first some basic calculations of the OEM IC and our potential ALTA IC’s. Using how the OEM IC is constructed, tube and fin, and comparing it to our potential bar and plate cores, we found we could make a core that fits in the OEM position and make it larger with more surface area, and a less restrictive core. We found we could make the Surface area bigger, and the ambient charge side bigger. Another simple calculation we made was the volume of the charge side entry. This would give us a way to compare how dense the OEM core is and compare it to ours which in turn gives us an idea on how restrictive the core might be. The first potential ALTA IC would be freer flowing as the charge side density was less given the overall increase in size, and it would cool the air better. So this all sounds good, except it wasn’t enough. For a small increase in these benefits, we would still be battling with ambient air flow issues. So IC design number 2 was calculating out to be better, and look far cooler. Like you would expect it to!
A few stats of the Intercoolers
ALTA proto vs. OEM
Cubic Inches 215% bigger
Charge Square Inches (charge tube only) 155% bigger
Fin density per square inch 20% less
Charge side square inch minus fin density 158% more
What does all this mean? Bigger core, more cooling potential, bigger freer flowing core, less pressure drop. So we know what we need to build on paper, on to the test. We have a plethora of different cores laying around the shop so creating the prototype was easy. Some sheet metal, and a couple of modded cores, and we have our proto. First off the proto fits the car perfect and if you made it to AMVIV you saw how it filled the bumper!
First few pulls showed great gains down low. The peak HP was about the same which has a lot to do with the boost the ECU runs at 5000RPM. Like previous runs sometimes the ECU would just not run the higher boost. But when it did the higher boost runs, we saw an increase in boost and power at low RPM. But because we were getting a little more boost than the ECU liked, it would close the Throttle body close to redline. Which I think that we could have seen more power from 6000 RPM up, had we been able to tune the ECU to run more boost. But very good gains at low RPM were had which is great sign of things to come!
Driving impressions. There is ZERO change in response. Even thought the volume changed, the turbo spools so quick there is not a single difference in feel, except more power!
An important thing to take note of is that the charge temps were far cooler. Before we were seeing about 150-155 at the end of the run, and 130 before each run. With the IC installed we never saw more than 110 degrees at the end of the run and 105 before each run. This is a huge improvement! We calculated STOCK IC efficiency at 63%, and ALTA IC efficiency at 85%, which is great! The core we used we have tested many times to show it is slightly restrictive, but cools very well. With the increase in boost we saw, and a slight change to get the pressure drop back to 1psi range (stock is no where near 1psi) I think there is a huge potential for this part. Especially when we start tuning the ECU to run more boost (higher charge temps), the ALTA FMIC will shine!
The final prototype core will be tested in the upcoming weeks, so keep your eyes peeled for that!
Above graph shows averaged runs with the 3" ALTA turboback, intake, and FMIC installed.
BOOST CONTROLER
The first obvious part we thought of was some type of boost controller. Our first boost controller worked very well at controlling boost. But the ECU sure didn’t like it. The ECU does 3 things to control boost. The ECU has an air control solenoid that varies its duty cycle to allow more or less vacuum (yes vacuum) to close or open the wastegate actuator to control boost pressure. If the engine is running more or less boost than programmed, the ECU first uses the solenoid to control the actuator, if that doesn’t work, then it blows the BOV off. Finally if that doesn’t work, the ECU closes the TB. When setting up and testing our 2 different boost controllers, we had a hell of time getting it just right. So we had to come up with a solution to the BOV blowing off, and keep the ECU happy. After some minor tweaks to the ALTA Blow Off Valve, we solved that problem. Now onto adjusting boost. Below is and example of some of the runs doing just that, and comparing it to a couple runs with the OEM boost controller. The really low power runs show the boost controller set below the stock boost setting and shows the ECU closing the TB and making the BOV blow off.
Above is our first runs with our boost controller installed. This shows that not enought boost and the ECU freaks out an dcloses the throttle body, and makes the BOV blow off.
Above is our best run with our boost controller installed. This shows that great power can be had, but a bit too much boost at upper RPMS made the ECU close the throttle body and loose power.
After the above runs we backed off boost a little to keep the ECU happy. We lost some of the peak power, and low end power, but got rid of the huge loss in torque. Over all the highest HP was had with the boost controller running on the ragged edge of what the ECU liked. If we can hold this, I think there is more than 30ft-lbs to be gained at lower RPM and easily 20WHP gained at low RPM. Our 2 different boost controllers will be available soon, but until there is a flash to get rid of the boost limits, it is kind of a pain to setup. This part will go hand and hand with an ECU flash when they are available.
A question that arises is, can this kind of boost control be flashed into the ECU? Who knows, because the wastegate actuator is vacuum controlled, I believe that some boost can be added, but not tons as the actuator may have a hard timing staying closed under boost, and when the turbo is first spooling up. But the 2 different ALTA boost controllers with an ECU flash will definitely work and work very well.
Supercharger Pulley for the turbocharged R56?????
This may be a little confusing for some, but the quest for the R56 “supercharger pulley” is upon us. This simply refers to a part that is rather inexpensive, but makes lots of HP. Or best bang for you buck! With the Supercharged Mini, we have all come to love the smaller SC pulleys. They are cheap, easy to install, and make big power. So what is this part for the new car? Well all of the parts we have designed, and tested all make pretty good gains with the stock ECU tuning. But the ECU is really holding us back.
So is the ECU flash the SC pulley? I am sure most are thinking yes, but a flash is going to cost more than the normal R53 flashes. So $800??? I think that takes it out of the running.
Is it the Intake system? Its not too expensive, easy to install and make 10 or more WHP. It’s a good choice, and with the cool sounds it adds, it could be the winner. But its still not tons of power.
The turbo back exhaust??
This makes tons of power and torque, makes cool sounds, and looks awesome on the car. This could be the winner! But cost is an issue. It’s a lot more than a SC and install. In a cost no object world, this is the winner by far, but we are still looking for that around $300 item.
The ALTA boost controllers…….hmmm. With the above graphs showing the gains, and the elimination of the big dip, this has good potential. For about the cost of a SC pulley and installation, this may be the ticket. The only issue is it needs to be adjusted, and that means some way of measuring the boost is needed. So gauges, or an OBD reader would be necessary. In the end to get the full use of the ALTA boost controllers, you would need some type of ECU tuning, or flash.
ALTA FMIC?? It’s not a good “Supercharger Pulley” type of part because its more than $300, not quick to install, but it definitely is the best looking part for your mini! Its potential for big power is huge and we believe that this will be one of the most popular parts.
ALTA flash…… This is something you will see in the next few months. Much is in the works, and you will see both R56 and R53 ECU flashes very soon.
So what is the Supercharger Pulley for the R56??? At this point there are 5 good candidates. The ALTA boost controllers I think are the best candidate and in the up coming weeks we will debut the parts and further testing of them. With that said, at this point, a combination of parts and the ECU flash will be an integral part of making the most from the R56.
Some interesting notes:
1. The car loves the individual parts being installed.
2. Combining the parts with other parts made more power, but not quite as exponential as we wanted.
3. With all the testing, the car is no where near the edge of performance, so lots of head room is left in the R56.
4. Breaking the 200 WHP will be easy!
5. Getting rid of the huge dip and loss in torque will be easy with a flash and or our ALTA boost controller.
6. The ALTA 3” turbo back exhaust produced the most HP of all the parts, and with minimal noise.
ALTA in the past is not one to “spill the beans” on our testing, but as we have come to see over the years, Mini people are a technical bunch of people, and like to see this. The downfall is our competition will also read this, and most likely learn things they never knew before they even get their hands on the new car. But we feel the public would like to see hard work that sometimes we hide when making parts. So I hope everyone enjoys the info, and I hope this helps shed the light on the new car! And for any of those out there thinking of trading up, go for it! The new car has many really cool things about it, and has tons of potential!
Feel free to ask us any questions!
Old Mar 30, 2007 | 01:57 PM
ALTA2's Avatar
ALTA2
Manufacturer
BTW,
Turbo isn't mentioned here yet, but of course it is in the works. Lots of pics to follow also.
Old Mar 30, 2007 | 02:07 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Looks great! How soon till the catback is ready? Price?
Thanks.
Old Mar 30, 2007 | 02:33 PM
Ryephile's Avatar
Ryephile
WOW, a fantastic barrage of information; THANK YOU! I still have to read through it again, but you guys are totally taking the cake and running away!
Hugs!
Ryan
Old Mar 30, 2007 | 03:02 PM
beken's Avatar
beken
When one of you showed my your car at AMVIV, I was quite impressed. The data you guys gather and then make the upgrades to is a very logical and well thought out way of doing things. Having had an Alta part installed in my car, I am confident of your quality. After being told that you folks are still developing parts for the Gen 1 "new" MINIs, I can't wait until my warranty expires and the upgrade bug hits me.
Just a question that has always been on my mind. Does redirecting airflow either by opening up the hood scoop or adding deflectors to direct air through the front mounted intercooler affect the aerodynamics of the car at all? Just being theoretical, by opening up the scoop, air enters the engine bay but may not have enough opening to escape except through the bottom of the car. Is it possible this may generate lift at the front of the car?
Thanks.
Old Mar 30, 2007 | 03:18 PM
BrewSwapGuy's Avatar
BrewSwapGuy
Formerly PassatDoTd
Way to go Alta! So many members here complain about not seeing the data. That certainly isn't the case here. And I hope they reward you with their business for your openness (I can't on these new parts since I have an R53 *with an Alta pulley*)
Old Mar 30, 2007 | 04:22 PM
MX100's Avatar
MX100
awesome!
you guys are definately on the top of my list when it comes to performance parts.
Thanks!
Old Mar 30, 2007 | 05:15 PM
MarioKart's Avatar
MarioKart
Vendor
I should sell my Mini and buy and an 07
Old Mar 30, 2007 | 05:59 PM
devious duck's Avatar
devious duck
I was already getting excited about the new car, and now i really can't wait to take delivery. This thing is about to be one Bad Mo with some upgrades.
Old Mar 30, 2007 | 07:43 PM
brohr01's Avatar
brohr01
I cannot wait for some more information to be relased about alta's new lineup.
The one product that i am most interested in would be a programmer that is end user tunable. Although i know great tunes / reprograms exist for the R53 i really like the idea of being able to tune the stock computer to your exact mods with you exact amout of safe / aggesive amounts of timing and boost. My friend has a ford focus and SCT has a "pro racer" package that includes a flasher (to upload the tunes via the obd port to the engine computer) and software for a laptop to be able to view and change every single table that is mapped to the ECU's memory. Complete control of spark, fuel, fuel pressure, shift point, ect. That would be a product i would jump all over no matter the price, the gains would be huge for the end user.
Old Mar 31, 2007 | 12:47 PM
familiarstranger's Avatar
familiarstranger
Alta, I personally have always been wary of tuners, so the fact that you can publish these kind of facts is very nice. People on the forums speak of alta and they speak of quality and service. that seems to be reflected here. the R56 is gunna be one bad mamma jamma when you guys are done with it
Old Mar 31, 2007 | 06:12 PM
manifest's Avatar
manifest
What was your gain in tq/hp when combining bolt ons and with what bolt ons? Thanks for all the information and pretty pictures! Excellent work!
Old Mar 31, 2007 | 07:28 PM
lava's Avatar
lava
Man! I'm impressed. Keep going!
Old Mar 31, 2007 | 09:32 PM
wrx_xb9r's Avatar
wrx_xb9r
I am really interested in the ECU flashes. Can this replace the need for a boost controller also? This would be similar to the Cobb AccessPort units. 20+%hp and 30+%tq gains are common on the Subaru's.
Info for others reading. The AP plugs into the OBDII and remaps the factory ECU. All variables are changeable. This means boost levels, fuel maps, ignition maps, etc. Gains of 10+% are reasonable with just an ECU reflash w/ raises boost levels and tweaks the rest of the maps. Adding turbobacks just increases the power levels.
Old Apr 2, 2007 | 11:32 AM
ALTA2's Avatar
ALTA2
Manufacturer
Thanks.
Catback will be shipping in about 4 weeks or so. I think we will have some at the Dragon! We will run a special price on the catback for $899, including shipping. Compared to other systems, it is 3" 304SS, uses high tech V-bands and clamps everywhere, straight through 3" mufflers, and Dual wall SS tips, that will not discolor, and of course will make the power we show above!
Hugs!
Ryan
Mmmmmmm, cake is good!
Thanks.
We will never give up on the old "new" mini. There are far more of these cars out there, far more of them falling out of warranty, and a far bigger playing field. In fact using the business plan of most large aftermarket companies, we shouldn't be touching this car for at least a year as there is just not enough cars out there. While that may be true, whats the fun in waiting, when you got this fun new car to play with!
Regarding your air flow issure. Lets take the new car. If you open up the scoop, the air will flow through it, then behind the engine out the bottom of the car. This is somewhat the same air path the air entering the front of the car, but some air will go out the bottom, not go over the engine. So will this effect aerodynamics? The new IC diverter, no, because the air is already entering the front of the car an going throught it. The scoop, yes but it wouln't be much. Definatley not enough to effect lift or anything like that, but if you had some before and after tests there would be a change, just microscopic.
Originally Posted by MX100
awesome!
Thanks!
Great! that is what we strive to do!
Not that it is pratical for everyone, but YES! For me, i always like the newest and coolest thing, and the 07 is very cool, and with its potential, many performance oriented customers will eventually trade up.
I don't think you will be dissapointed when you get your car!
You're excited?? I AM EXCITED! It just can't get done soon enough!
We get comments like that alot, and like when we made our intake for the R53 years ago, we pulished the numbers, and if you look on our site, we have solid real world numbers on most everything! If we hide or make up things, eventually people find out. That is not good business. In fact, had our intake not worked, or something we would have showed that and made changes until it did.
Like the FMIC! It worked, but we can make it better. So in the next month or so you will see just that!
For instance with the Turboback exhaust the peak HP didn't change much, when we installed the intake system. It was about 3WHP at the peak, but after the peak there was a good 5-7HP gained. Its less than the 10-12WHP with it on a stock car. Still good, but not as good. The final dyno runs with all the parts installed were the highest HP runs, so its not like they didn't help!
We never stop!
Will it replace the boost controllers? Maybe. I think that the some boost can be increased with the strange OEM vacuum actuator, but i think there is a lot to be gained by ditching it. Main in response! Most Cars have pretty high exhaust pressures before turbos. 3x is not uncommon. Since the vacuum pump can really only pull -14psi (which i think is a high guess) and using the size of the actuator, it will be hard for the vacuum to hold the high exhaust back pressure. BUt that is yet to be determined. When we can tune the ECU we will quickly discover if this is problem.
When we can flash and tune, like the WRX, gains of 20% are not going to be out of the question.
The other obvious part you will see soon is an upgraded turbo!
Old Apr 2, 2007 | 12:26 PM
Loony2N's Avatar
Loony2N
Thanks! I know where I will look first when mod time comes. I think a lot of people prefer to shop from the guys who put the customer first, so I am sure your spilling the beans will bring you many more beans than your freebies to the competition will cost you!
Old Apr 2, 2007 | 01:55 PM
benfica09's Avatar
benfica09
awesome work guys!
can't wait to get my hands on that exhaust.
Old Apr 21, 2007 | 07:40 AM
RR56's Avatar
RR56
I want an intake for the Dragon!!!! When will they be ready?
Old Apr 23, 2007 | 12:30 PM
ALTA2's Avatar
ALTA2
Manufacturer
I would say in 4 weeks or so. We should have catbacks at the dragon, at least a few of them! But if you are wanting a specific color, let us know and we will put it on back order for you.
See you in a week or so!
Old Apr 24, 2007 | 02:19 PM
Ryephile's Avatar
Ryephile
I'm looking forward to seeing what you guys come up with for an airbox. The stock piece looks pretty expensive, however I imagine a molded velocity stack on the end of the MAF meter with an UNI filter wrapped around it all would be the cats meow. You guys doing something like that? (*hint hint*)
Old Apr 24, 2007 | 06:28 PM
jonnieoh's Avatar
jonnieoh
Kudos to you, ALTA, for sharing/being so upfront. It's great to see an innovative vendor who isn't afraid of showing their progress. This is all very exciting for the R56 owners out there. I almost wish I was one of them... almost.
But I love my R53 too much. Keep up the good work.
Jonnieoh,
another happy ALTA customer
Old Apr 30, 2007 | 05:49 PM
mikeg4572's Avatar
mikeg4572
How you lookin on the downpipe?
Old May 10, 2007 | 11:23 AM
ALTA2's Avatar
ALTA2
Manufacturer
The Downpipe is on the way, and we should be shipping them in 3 weeks or so!
Here are a few more parts on this THREAD to add to the R56 cars.
Old May 11, 2007 | 06:33 PM
MIN 18's Avatar
MIN 18
regarding the intake test result above, was it just the result of changing the drop in air filter?
Old May 14, 2007 | 11:36 AM
ALTA2's Avatar
ALTA2
Manufacturer
The intake test is our complete intake system. Filter, box, intake hose, and fresh air coupler. The drop in filter was not dynoed, but will be very soon! We do expect gains with it, but how much is the question!
