R52 Discovered something new this morning
Old Mar 30, 2007 | 06:19 AM
davavd's Avatar
davavd
I can't believe that after this long (10 months), I am still finding things. After I got off the interstate this morning (top down/all windows up), I hit the button for the back windows. Usually I hold it down, but this time I decisded to try and see if it had an auto-down like the front windows. I wasn't surprised that it did, but I was surprised that the front windows then follow right behind.
Sooooooo cool! I know, I know, all the rest of you figured that out in the first 15 minutes you had the car.
Old Mar 30, 2007 | 06:55 AM
mgibson61611's Avatar
mgibson61611
Thanks! That's a new one on me, I knew if you held them long eneough the fronts go (or I mean, I think I read it in the manual), but not the auto thing!
Old Mar 30, 2007 | 08:21 AM
VicSkimmr's Avatar
VicSkimmr
They'll go down automatically?!
Old Mar 30, 2007 | 09:04 AM
The Red Wolf's Avatar
The Red Wolf
Well I'm just the opposite. I knew that the button controlled all the windows- that's how I've always controlled the front windows- but I had no idea about the auto-down, that will be very handy (and less distracting as put the windows down while driving a lot). It was a little cool this morning, so I left the windows up, I'll try out the auto feature when I get in for the drive home tonight. Thanks for the tip.
Old Mar 30, 2007 | 05:46 PM
ThomB's Avatar
ThomB
Yep, a quick tap of the down button sends them all down... Wish it'd do that to go up too...
Old Mar 30, 2007 | 06:57 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep - I found that by accident also about 2 weeks ago. Way cool.
Old Mar 31, 2007 | 03:01 AM
btallack's Avatar
btallack
I found that out after owning my car for about a month when my finger slipped off the button right after pressing it.
Old Mar 31, 2007 | 05:55 PM
rkw's Avatar
rkw
Here's a tip. The fastest way to put down the roof when the car is fully closed:
  1. Quickly tap (and release) the open windows button.
  2. IMMEDIATELY press the open roof button (even while the rear windows are still going down)
  3. As soon as roof stops (sunroof position), IMMEDIATELY press again to put down the roof (even while windows are still going down).
The trick here is that the auto-down windows works independently of the roof, and you can simultaneously put windows and roof down. Step 1 initiates the auto down for all 4 windows, and while the windows are still going down, it does not prevent you from putting the roof down. If you use only the roof down button, you have to wait during the part of its sequence where it rolls down the windows.
Another tip, if you are driving and want to put the top down: before you stop, first open everything as far as you can. While still moving, use the auto down windows and also open the roof to sunroof position. When you come to a stop (such as at a light), the roof takes very little time to go down the rest of the way.
Old Apr 1, 2007 | 09:26 PM
homerwest's Avatar
homerwest
Cool stuff - can't wait to use it!
Old Apr 2, 2007 | 07:17 AM
eager2own's Avatar
eager2own
Yep, I always use this feature, even if I'm only lowering them partway (like when I lower the back ones partway when using the sunroof feature). Tap once to start the process, and tap again to stop it.
Old Apr 2, 2007 | 07:34 AM
holdenontoit's Avatar
holdenontoit
GBMINI has an auto up circuit ( I think he's a vendor on this site?) He also has a modification for track mode DSC so that the DSC is turned off when you start the car and must be manually turned back on instead of vica versa. And lastly he also has a garage door opener option too.
https://www.northamericanmotoring.co...%2Findex.shtml
Old Apr 23, 2007 | 09:20 AM
Porco Rosso's Avatar
Porco Rosso
Incidentally, after tapping for the auto-down feature, you can also quickly tap the button again at any time to stop the windows at whatever point they're at.
Old Apr 24, 2007 | 08:53 PM
zzMini's Avatar
zzMini
I use this behavior to put only the back windows down if I have the sunroof open. Reduces noise - learned that on this site.
Though frankly, the only time I ever had the top in sunroof position is for experimentation - most of the time the top is down all the way.
Old May 5, 2007 | 12:25 PM
MINIFVR's Avatar
MINIFVR
Nice to know...i never knew you could open the windows and top down at the same time. Having the passenger window up and drivers side down keeps the wind from blowing to the front in cold weather too.
drrigg
May 27, 2022 03:31 AM
ian260
Mar 29, 2017 06:08 AM
randeez
Oct 5, 2015 09:23 AM
NYXF56JCW
Oct 3, 2015 04:27 AM
donniedarko
Sep 29, 2015 01:16 PM
