"Jack Point" underneath the MINI is Missing!
Old Mar 29, 2007 | 08:37 AM
PortMCS's Avatar
PortMCS
Well i just went outside to jack up the car with the stock floor-jack. Come to find out, when i look underneath the aero side-skirt to look for the "jack point" (feels like a hard block of box plastic ) the Jack point behind the drivers front wheel is missing! I felt around underneath and i have all the other 3. There are 2 on each side of the car, im just missing the drivers front. So heres my question.
Can i use something of similar shape and firmness in place of it in that empty space ? I surely dont want to use the jack on the aeroside plastic! O
OR, just borrow a real jack to get deep under the car and lift it on the frame ?
This is a real bummer cuz i was gonna paint the calipers at the same time and then mount my new 18" wheels as im off today
Old Mar 29, 2007 | 10:54 AM
ScottRiqui's Avatar
ScottRiqui
No worries, you can use the factory jack point even with the plastic block missing. I'd put a piece of wood between your jack and your car, as you suggested.
I don't usually use the factory points when jacking up the car, anyway, since that's where I like to put the jackstands. I just put a long, flat piece of wood under the sill between the two jack points and use that to jack up the entire side of the car, then slip stands under both factory points at the same time.
Old Mar 29, 2007 | 10:55 AM
JCW Driver's Avatar
JCW Driver
A wood 2x4 that is a couple feet long, between the jack and the framerail should be OK.
EDIT: Ok scott beat me to it, with a better response.
Old Mar 29, 2007 | 12:23 PM
rrdusek's Avatar
rrdusek
replace them all with texas speedwerks ones and never worry again.
Old Mar 29, 2007 | 04:14 PM
Duane's Avatar
Duane
Options
I have lost them too. I just buy them at the dealer, don't remember them being over 20 bucks. It takes you longer to kneel down then it does to install them. But in the meantime, just keep jacking, you can lift the whole side from either the front or rear pick up point.
Old Mar 29, 2007 | 04:18 PM
gmcdonnell's Avatar
gmcdonnell
+1
Old Mar 30, 2007 | 06:10 AM
PortMCS's Avatar
PortMCS
Thanks for the sugestions guys! I did put a smal wood block on top of my jack and it worked out great!
Old Mar 30, 2007 | 09:00 AM
Scooby03's Avatar
Scooby03
We stock the oem jack points, and sell them for under $9.00 each.
Brad
Custom Mini Shop
Old Mar 30, 2007 | 09:45 AM
pauliekeys's Avatar
pauliekeys
Originally Posted by gmcdonnell
+1
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
