Tire Change Damage
Old Mar 20, 2007 | 07:15 PM
jsd356's Avatar
jsd356
Tire Change Damage
Can wheels be damaged when installing low profile tires? I got this feeling earlier today when I took new tires/wheels into a local chain to be mounted. The employee working at the time stated a charge but upon seeing the low profile tires, he mentioned that $10 extra is usually charged per tire for low profile. I went back later to find that only two of my wheels/tires had been finished and I would have to come back tomorrow. He seemed to be having a difficult time getting this work done although he told me, up front, that it took longer to install low profile tires.
All of this makes me believe that damage is possible. Is a special machine needed for low profile tires? Am I right or over-reacting?
Old Mar 20, 2007 | 08:43 PM
VoiD's Avatar
VoiD
My understanding is lower profile tires tend to have stiffer side walls making mounting harder..
make sure to do a good inspection before leaving the store..
Old Mar 21, 2007 | 08:36 AM
Alex@tirerack's Avatar
Alex@tirerack
Good hardware helps, a pacient skilled tech is almost more importand, imo
Alex[
Old Mar 21, 2007 | 09:14 AM
Wake|MCS's Avatar
Wake|MCS
Yeah it does take a tiny bit longer to install low profile tires, but it shouldn't take him all day lol... Be sure to inspect your wheels though, cause most techs aren't careful with YOUR wheels, they just wanna get the tires on there...
Old Mar 21, 2007 | 09:18 AM
xizor's Avatar
xizor
that's my experience as well, low-profiles cost more.
Old Mar 21, 2007 | 09:25 AM
BlimeyCabrio's Avatar
BlimeyCabrio
The inside surface of one of my wheels got gouged up nicely when I had a tire changed recently. Argh. Luckily not visible when installed. But I know it's there....
Old Mar 22, 2007 | 03:30 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Shops that have experience and the right equiptment to handle your tire mounting needs is most important no matter what the charge is.
Normal mounting and balancing can be done at any garage but low profile tires, alloy rims, and runflat tires are troublesome, require more skill and better equiptment.
Risk of damage to rims is very real. Talk to the mechanic or shop about their experience. Cheaper places will not even take your low profile tires and allow rims.
Old Mar 22, 2007 | 05:32 PM
95Viper's Avatar
95Viper
If you have ever seen the new Hunter mounting and balancing machines you will understand how the chain stores that don't have them hack up rims.
Colt45Magnus
Sep 7, 2015 10:47 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
minipopkart
Aug 13, 2015 05:22 AM
Dashdog
Aug 10, 2015 06:17 AM
