Suspension Taking a rear trailing arm bushing poll
Old Mar 15, 2007 | 10:37 AM
meb's Avatar
meb
If you have replaced your rear trailing arms with a new bushing, can you give the mileage at the time of replacement and how the car was driven ie, commuting and track or track only etc.
Old Mar 15, 2007 | 10:41 AM
txwerks's Avatar
txwerks
I'll weigh in shortly... I am installing the IE rear inserts this weekend in my daily driver. It'll get the first track workout at AMVIV, and I'll report back after the drive out there (1200 miles), the track work, and return trip.
Old Mar 15, 2007 | 12:00 PM
meb's Avatar
meb
I've had these stting around for a year now, but I haven't installed them...a few have stated they actually make the backend a bit more nervous. The IE are suposed to reduce rear steer...
Let us know for sure!!!
Old Mar 15, 2007 | 12:11 PM
Petrich's Avatar
Petrich
Alta spherical ball joints - 20,000+ miles
Michael,
Have had the Alta's in for 3 years, well over 20,000 miles of mixed street and a lot of track time. Seem fine. No noise, no complaints.
John Petrich in Seattle
Old Mar 15, 2007 | 12:50 PM
k-huevo's Avatar
k-huevo
I replaced the 2003 model year brackets & bushings at the 61,000 mile mark plus added Power Flex poly inserts. Yes, understeer was reduced greatly, however, the rear felt like an over-inflated tether ball; about 200 miles later I removed the poly inserts. Things may be better with the way the later model trailing arm articulates.
Old Mar 15, 2007 | 03:28 PM
cristo's Avatar
cristo
Alliance Member
How easy are they to install? Do you have to reset the toe-in at the back after,
or can the 3 bolts that keep the toe-in locked stay tight?
I have an 3/2003 suspension.
Old Mar 15, 2007 | 06:22 PM
002's Avatar
002
I did the inserts at 60k. They felt great to me. Now that I'm at 100k+ it is time for new bushings. I'm sure that the inserts helped them to go that long. My other car with stock original bushings is just plain scary at 80k miles.
Old Mar 16, 2007 | 05:17 AM
meb's Avatar
meb
I have 85K miles now with a number of track events thrown in for good measure, er, good abuse
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
