What size tires come on '07 17" wheels ?
Old Mar 11, 2007 | 09:16 AM
reelsmith.'s Avatar
reelsmith.
Does anyone know what size tires MINI is supplying on the R56 MCS with 17" wheels?
Thanks.
dean.
Old Mar 11, 2007 | 01:47 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
205/45-17
Old Mar 11, 2007 | 02:36 PM
reelsmith.'s Avatar
reelsmith.
Thank you. I appreciate it.
dean.
Old Mar 11, 2007 | 05:05 PM
minihune's Avatar
minihune
dean.
For the stock sized rim you can fit the following sized tires using stock suspension-
205/45-17
215/40-17
215/45-17
225/45-17
Once you lower your car you will have less clearance and if you change to aftermarket wheels with less wheel offset you many have slightly less clearance and 225/45-17 will likely not fit.
Safest option is the stock 205/45-17.
Of these 215/40-17 runs smaller than stock but has a slightly lower load rating which is OK for performance use and just the driver in the car. If you tend to drive with four people then it's not as good a choice. The 40 series sidewall tends to be very stiff and not the best choice for areas with poor roads and lots of potholes.
kazyn
Oct 25, 2019 02:34 PM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
Edgar78
Aug 15, 2015 05:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
