R56 oil filter
Old Feb 28, 2007 | 07:19 PM
Roneboy's Avatar
Roneboy
oil filter
Is the oil filter on the r56 engine a spin type or is it the same old canister type.
Old Feb 28, 2007 | 07:21 PM
MotorMouth's Avatar
MotorMouth
I haven't opened one but it looks like the can type.
Old Feb 28, 2007 | 07:32 PM
daffodildeb's Avatar
daffodildeb
It is.
Old Mar 1, 2007 | 03:04 AM
glangford's Avatar
glangford
At least on the cooper it looks alot easier to get to than the old engine. front drivers side of the engine bay (see press launch pictures). Looks like alot of clear room. A couple of inch extension on the ratchet should clear about everything and allow for free movement of the ratchet. On the S it will be a little more difficult, not sure but you may have to remove the turbine duct to get to it.
Old Mar 1, 2007 | 02:31 PM
Roneboy's Avatar
Roneboy
Thanks guys for the info. Do you think that Mini is still using the can to protect the fiter because its so low to the ground?
Old Mar 1, 2007 | 04:07 PM
glangford's Avatar
glangford
No, totally environmental reasons. You throw away a piece of paper and plastic, not a metal can every change. It's not that low compared to most cars. On the MC will be easily accessible from the top. MCS as well when you disconnect turbo duct.
Old Mar 1, 2007 | 04:35 PM
Roneboy's Avatar
Roneboy
Thanks glangford for the reply.
Old Mar 1, 2007 | 09:05 PM
Ryephile's Avatar
Ryephile
I hope the R56 uses the same filter element as the R53, cuz I have a stash of R53 filters in my garage, LOL. It'll be interesting to see what has to be removed to access the filter canister on the MCS; it looks very easy to get to it on the Cooper [jealous!]
Old Mar 2, 2007 | 02:44 AM
glangford's Avatar
glangford
I'd like to know if it does use the same filter element. Let us know if you find out.
Old Mar 2, 2007 | 03:37 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Looks like 2 differant part #'s.
R53 1142751446
R56 11427557012
http://www.realoem.com/bmw/showparts...95&hg=11&fg=30
http://www.realoem.com/bmw/showparts...30&hg=11&fg=30
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
Chasp
Aug 25, 2015 06:44 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
