Suspension Rear Camber?
Old Feb 26, 2007 | 08:17 AM
inomis's Avatar
inomis
Rear Camber?
Anyone know what the stock rear camber should be? I noticed from the sand my tires picked up that there appears to be some negative camber in it.
Old Feb 26, 2007 | 08:52 AM
Ryephile's Avatar
Ryephile
I would guess stock rear camber should be about -1.0 degree, but I don't have any offical documentation to back that up. A bit more camber will buy you a bit more stability in corners, and a bit less camber in back will buy you a little better rotation in the corners. At least that's my experience with the R53. The rear suspension on the R56 is very similar.
ebowling
90
Aug 4, 2019 09:15 AM
Mini7
Feb 2, 2016 07:52 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
