Drivetrain NEED HELP brake vibration
Old Feb 25, 2007 | 03:02 PM
littlecS's Avatar
littlecS
I was replacing my brake pads and after I was done the pedal was very soft and I was getting terrible vibration at 35mph when braking. I changed the front pads only, tried to do the rears but couldn't without the special tool. We also bled the brakes a little so its a possibility that air got in the lines, although i doubt it as we were using two people and bled quite a bit of fluid. Any idea on where the vibration is coming from? I plan on bleeding the brakes again.
Old Feb 25, 2007 | 04:31 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Stupid question! Did you make sure you cleaned your rotors and new pads of any and all oil you may have deposited on them during the install?
Old Feb 27, 2007 | 07:15 PM
Squirrel's Avatar
Squirrel
Uh-oh...I have the same problem. Miminut, I didn't clean my rotors or pads (installed last saturday). What am I in for?
- squirrel
Old Feb 28, 2007 | 02:29 PM
littlecS's Avatar
littlecS
well i did the replacement on saturday night (only took about an hour for the fronts) and since we planned on doing the rear also my friend loosened the back left lug nuts, but not completely. turns out the loose lug nuts were causing the vibration. guess you shouldn't work on your car at 11:30pm =D
patsum
26
May 29, 2021 06:29 PM
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
