Drivetrain NEED HELP brake vibration
I was replacing my brake pads and after I was done the pedal was very soft and I was getting terrible vibration at 35mph when braking. I changed the front pads only, tried to do the rears but couldn't without the special tool. We also bled the brakes a little so its a possibility that air got in the lines, although i doubt it as we were using two people and bled quite a bit of fluid. Any idea on where the vibration is coming from? I plan on bleeding the brakes again.
well i did the replacement on saturday night (only took about an hour for the fronts) and since we planned on doing the rear also my friend loosened the back left lug nuts, but not completely. turns out the loose lug nuts were causing the vibration. guess you shouldn't work on your car at 11:30pm =D
patsum
26
May 29, 2021 06:29 PM
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
