Boot Leaking
Old Feb 24, 2007 | 11:38 AM
fiddlin2000's Avatar
fiddlin2000
Boot Leaking
Just wondering if anyone else has experience any problems with this before.
Went to load some groceries in my MINI this morning (yes, we use it for grocery shopping...) and noticed there being some rust stains, etc. on my boot mat. Upon further investigation, I noticed that the carpet underneath the mat was completely saturated with water, and... the battery compartment was more than halfway full of rusty, stagnet water. I know this can't be good with all of the little electronic modules, wiring harnesses down there. I always make sure that the boot lid is fully closed and the "open boot" light has never came on before, so I'm fairly certain I'm not at fault. I'm assuming the weather stripping around the lid is faulty or something... I'm just really uncertain as to how all of that water got in there. Anyways, I do have an appointment at Mini of Dallas Monday morning, hopefully they'll be able to resolve it.
Was just curious if anybody else has had this happen to them or else it's just a freak, isolated incident.
Thanks for any imput anybody has.
~ John
BTW, It's an '04 MCS with the battery in the boot... if that has anything to do with it.
Old Mar 9, 2007 | 03:46 PM
sdv515's Avatar
sdv515
mine leaks too. found that out when i went to change into another shirt and pulled a nice wet one out of the back.
Old Apr 19, 2007 | 01:27 PM
minizeeg's Avatar
minizeeg
same problem...have either of you found the solution. I lost half of my artwork becasue i had my portfolio for college back there.
Old Apr 19, 2007 | 03:31 PM
sdv515's Avatar
sdv515
not yet. i just park in the garage now and dont drive it in the rain
Old Apr 19, 2007 | 04:37 PM
NMgokart's Avatar
NMgokart
There may be other issues involved (like a faulty seal), but have any of you "leakers" tried adjusting the boot latch? Fairly easy to do, just pop off the screw covers on either side of the latch striker (that squared-off hoop thingy), loosen the bolts, and move the latch striker in a bit. This will make the boot close a little tighter against the seal.
Again, you may have other issues, but give it a try.
Old Apr 19, 2007 | 05:39 PM
Rawhyde's Avatar
Rawhyde
Lots of people have had this problem. It's usually the drain hose for the sunroof. That was the problem with mine.
Rawhyde
Old Apr 19, 2007 | 06:27 PM
techtipz's Avatar
techtipz
Some can be from the rear glass, from the third brake light, or from the antenna. Third brake light is kind of easy to tell. If it looks like it is retaining water, it is probaly leaking through the screw holes into the rear.
Filmy
15
Jun 6, 2023 06:27 AM
67morris
Dec 1, 2015 12:53 PM
Sep 10, 2015 03:36 PM
kjd186
Sep 9, 2015 10:02 AM
Sep 2, 2015 09:05 AM
