WTB. Concentric Rings for TD Pro 1 Wheels
Old Feb 7, 2007 | 05:43 PM
djdport66's Avatar
djdport66
Does anyone know who stocks these rings for the TD wheels? I just ordered a set and they did not come with the rings to fit the hubs! Thanks
Old Feb 7, 2007 | 06:00 PM
jonnieoh's Avatar
jonnieoh
You should call Discount Tire, and order their anodized aluminum HUB-CENTRIC rings, to be precise.
You'll need to know the inner and outer dimensions, in millimeters. The inner diameter is 56.15mm, but the outer diameter is whatever your wheel manufacturer says it is. I would ask the manufacturer, and not simply trust your measuring skills with a ruler. Get the exact diameter; as ordering the correct size is imperative.
Also, there are some plastic hub-centric rings out there, but they can melt with heavy braking, (like track days and autocrossing). Aluminum rings are going to stand up to the heat.
Old Feb 7, 2007 | 06:11 PM
jonnieoh's Avatar
jonnieoh
Discount Tire Direct:
http://www.discounttiredirect.com/direct/home.do
1 800 589-6789
The rings aren't listed on their web site, (or if they are, they're really hard to find). I called them, and placed the order, just a couple weeks ago. It was easy, and they arrived within 2 days, standard shipping! Not bad!
Old Feb 7, 2007 | 06:19 PM
Carol@PaloUberMini.com's Avatar
if you tell us your hub size, you can order our rings online, which,unlike nylon, are anodized aircraft aluminum. we also are the only manufacturer in the world who has 14mx1.25m tuner lugs for the new mini/after 6/06.......
www.paloubermini.com hope this helps, bryce
Old Feb 7, 2007 | 06:21 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
If I recall the bore size for my 17" TRD PR1's are 73.1mm and the MINI stock bore is 56.1mm as stated above. around $15 for all 4 at discount tire direct and are anodized aluminum.
Old Feb 7, 2007 | 06:22 PM
1 800 589-6789
go to www.paloubermini.com anodized aircraft aluminum rings and we are the only manufacturer in the world for high performance 14mx1..25m tuner lugs designed exclusively for the mini, f-1 track rating of 10.3 ...hope this helps,bryce
Old Feb 7, 2007 | 06:43 PM
djdport66's Avatar
djdport66
Ah, thank you very much G.C.! that was exactly the information I needed.
DJD
Old Feb 7, 2007 | 06:48 PM
djdport66's Avatar
djdport66
PM sent, thank you! DJDport
woodstudio
Mar 15, 2020 08:28 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Mini'mon
Aug 16, 2015 04:15 PM
jrezzo
Aug 9, 2015 10:32 PM
