Steering wheel vibrates
Old Feb 3, 2007 | 09:48 PM
cccm's Avatar
cccm
I have changed my wheels to 17x7 and running on 215/45/17 tires
and I have noticed that my steering wheel vibrates when i get up to 80km/h
I was just wonder what went wrong and is there a fix for it?
PS: I have yet to do alignment after changing my wheels
Old Feb 3, 2007 | 10:14 PM
SB's Avatar
SB
You don't need to do an alignment when changing wheels. It sounds like the tires were properly balanced. Carry it back to the place of install and let them know. I've had to do this so it's not out of the ordinary.
Old Feb 3, 2007 | 11:08 PM
BBCooper's Avatar
BBCooper
are you using hub rings??
My experience was...
I had the plastic hub rings that the tire shop "said" would work .. But I could feel the vibration when driving.. I had the alignment checked before getting the new wheels - so I knew that was not the problem.. I kept insisting that metal hub rings were needed for a proper fit. Plus I heard that some of the plastic rings can get messed up with frequent tire rotations.. Finally they got a metal set in .. and wow.. it was smooth as glass..
Maybe that helps..
Old Feb 4, 2007 | 06:25 AM
95Viper's Avatar
95Viper
Hub rings, not balanced properly, could need road force balance, check to see how much weight they put on the wheels. I one is excessively balanced it probably needs the tire dismounted and spun. Should check mating surface on hub and new wheels. If not prepped properly wheel could be sitting off balance.
Old Feb 4, 2007 | 10:42 AM
cccm's Avatar
cccm
I am using plastic hub rings right now
would you guys recommend me to get metal ones?
Manny_cooper
Sep 10, 2015 11:09 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
