Can or Has anyone run E-85 in their Mini???
Old Jan 30, 2007 | 06:21 AM
maginter's Avatar
maginter
I am curious as to if Mini's are set up to run E-85. Anyone have any input?
TIA,
Mark
Old Jan 30, 2007 | 06:30 AM
Paul's Avatar
Paul
I don't think E-85 will work. Nothing but premium going into my MCS
Old Jan 30, 2007 | 02:35 PM
SRICHS's Avatar
SRICHS
DO NOT RUN E-85 IN A MINI!!!!! Unless you like to talk to the crew at roadside assistance, the E-85 fuel is horrible for a MINI.
Old Jan 30, 2007 | 06:06 PM
nixjosh2's Avatar
nixjosh2
I refuse to contribute to the tortilla shortage
Old Jan 30, 2007 | 06:36 PM
MOE4me's Avatar
MOE4me
I wouldn't run E-85 in my Mini-bike... Don't believe the hype.
Old Jan 30, 2007 | 06:56 PM
javelina1's Avatar
javelina1
the manual says not too. good enough for me. Stick with the 91 premium.
Old Jan 30, 2007 | 06:57 PM
kapps's Avatar
kapps
Ethanol is not good for cars that aren't meant to use it. It's doesn't have the lubricating properties of gasoline so certain parts of the fuel system suffer. Also, ethanol doesn't have as much Btu per unit mass as gasoline so more ethanol must be injected to get the same amount of power (not to mention the stoichiometric A/F is different). Currently, stations blend up to 10% ethanol into the regular gas pumps as the law prohibits any more. Some cars have trouble with just 10%.
That said, ethanol does have a very high octane number. For most cars, this doesn't matter but I believe the Bugatti Veyron makes 50-100 extra hp when running on ethanol as the ECU increases boost.
Old Jan 30, 2007 | 07:03 PM
planeguy's Avatar
planeguy
The SEARCH BUTTON is in the upper right!
phrza81
Oct 10, 2015 11:37 PM
minicoclub
Aug 25, 2015 09:07 AM
bleonard1401
Aug 11, 2015 02:53 PM
Lt. Dan
Aug 10, 2015 12:46 PM
