Cleaning under the hood
Old Jan 23, 2007 | 05:13 PM
bumbLB's Avatar
bumbLB
Does anyone have recommendations for cleaning under the hood. I have always been worried about spraying parts that should not be sprayed with water.
Old Jan 23, 2007 | 06:40 PM
javelina1's Avatar
javelina1
probably wouldn't want to spray down a freshly run engine, (really hot).
Old Jan 23, 2007 | 06:49 PM
mcdbrendan's Avatar
mcdbrendan
You can spray it with water, jsut be mindful of the electronics and try to use a soft stream of water instead of a jet. Definatly try 303 Aerospace Cleaner from DetailersParadise.com
Old Jan 24, 2007 | 10:07 AM
jeffcaplan's Avatar
jeffcaplan
Any issues with getting water insider the injectors if there's a gap where your plugs/wires are?
Old Jan 24, 2007 | 09:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Is there any benifit of cleaning the engine bay or engine block itself besides aesthetics?
Old Jan 25, 2007 | 04:28 AM
B&D's Avatar
B&D
I use a Scuncii(tm) steam cleaner.
It's sorta like the "Shark Steam Cleaner" they have on the infomercials, but the Scuncii is a true "closed-pressure" steamer, with some great attachments for getting in the hard to reach places.
The high pressure steam cuts through grease & grime (without chemicals) and you don't have to worry as much about the electro-mechanicals under the bonnet, because you can very easily and precisely direct the steam where to go.
I use some old rags to wipe off the loosened grime once the steam does its job. It took about 30-45 minutes to detail my engine to a tee.
Bear in mind, I used it to get my engine "show car ready," - so for a "once in a while" cleaning, it would take about 15-30 minutes to clean your engine bay to great satisfaction.
AND... if you have to get your MINI serviced, you can bet that your mechanic will respect you and your MINI for serving up a nice clean engine bay.
-B
Old Jan 25, 2007 | 07:36 AM
Krookid I's Avatar
Krookid I
I wouldn't use a water hose...B&D has the right idea, but if you do use a hose definitely cover any electrical wires, especially the distributor cap and you want to cover the alternator (not sure if it is exposed). My friend cleaned under the hood and forgot to cover the alternator, the car alternator and battery were dead within a day.
Old Jan 25, 2007 | 10:32 AM
kenchan's Avatar
kenchan
i only do a wipe down with simplegreen 50/50 with water or 100% on
really greasy parts on paper towels.
i think you can find other cleaning info in the Detailing Forum too.
Old Jan 25, 2007 | 03:01 PM
apexer's Avatar
apexer
I have been spending 30 min. or so wiping down everythig I can reach under the bonnet everytime I wash the car since it was new. Really can't say its ever been dirty under my bonnet
YO MUDA
Oct 5, 2015 04:14 PM
minners
Sep 21, 2015 09:26 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
Sep 3, 2015 01:45 PM
MiniSMan
Sep 1, 2015 06:49 PM
