Help. Clicking Noise!
Old Jan 23, 2007 | 09:36 AM
boostedmini03's Avatar
boostedmini03
Okay, so.. I have a problem. I get this clicking sound coming from the engine when I drive and/or rev the engine. At this same time I found out that it was low 3 qts of oil. I filled it back up with oil, and it helped the sound a little, but I still hear it frequently.
My guess is something is screwed up with the valve springs.. anyone else have this problem?!
If someone really thinks they know what the problem is.. give me a call.. 614-565-6408. Otherwise, post your response. lol. Thanks.
Old Jan 23, 2007 | 12:48 PM
joey1320's Avatar
joey1320
the lifters are hydraulically(sp?) set with oil pressure. so top the oil and take it for a spin and see if it helps. you may need to get them warm and tehn let them cool off and try again.
good luck!
Old Jan 23, 2007 | 01:44 PM
Bigcoyote's Avatar
Bigcoyote
The only other thing that I know causes the "ticking" sound that is RPM related is the harmonic balancer ( damper ) that sometimes seperate. My 04 S had this happen and it took the MINI dealer several days to figure it out.
We went through alot of BS to find out what it was - double check it - it could be a easy fix.
Good luck
Old Jan 24, 2007 | 11:45 PM
boostedmini03
i figured it out. it was a rod bearing. i'm screwed. thanks for the replies though.
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
damncajun
Aug 17, 2015 08:25 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
nismo4life
Aug 5, 2015 08:31 AM
