Remove Alta crank pulley?
Old Jan 17, 2007 | 06:45 AM
TampaMCS's Avatar
TampaMCS
Do you need a gear puller to remove an Alta crank pulley?
Old Jan 17, 2007 | 07:14 AM
stevecars60's Avatar
stevecars60
The simple answer, YES.
There are 3 provision holes for a puller on the pulley. Your local auto parts should have a small puller that would work. You may need to buy some metric bolts to fit the pulley, other than that it is a relatively easy job. I think the bolts needed & the pattern are the same as your OE unit ( 99% sure ).
Old Jan 17, 2007 | 01:25 PM
TampaMCS's Avatar
TampaMCS
Ok, I figured I would, I found the dimensions for the bolts, I think I might actually have a gear puller, just gotta look.
Teh
Aug 22, 2022 04:37 AM
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
tr3y003
Oct 22, 2015 10:48 AM
keck.j
Aug 18, 2015 08:18 PM
