225/17/45 on stock rims possible
Hi Guys,
I have a 2006 Mini Cooper S with 17" wheels, if i am correct the stock 17" rim width is 7" so i just want to check if it is alright for me to put some Michellin Pilot Sport 225/45/17 tires, i am on completly stock suspencion set-up.
thanks
for the help
thanks
for the help
not sure about all stock wheels but my webspokes were 17x7
i put toyo proxe s4 215/40's them and i personally didnt like the look... they didnt appear to fit well for me, rim was too skinny... just my opinion
225/45/17 Kumho Ecsta MS on 2005 MCS
I previously had 224/45/17 Kumho Ecsta MS on my 2005 MCS. They looked great and I don't remember having rubbing issues. The car is stock height.
I need a new set and am considering the same tires or the new Ecsta XS series in the same size. Any comments, opinions would be welcome. Thanks!
225/45-17 will fit stock wheel
Rubbing might happen under load with four people and stuff in the MINI or over dips.
The stock tire diameter is about 24.3" and this tire is too tall at about 25"
A better choice would be-
205/45-17
215/45-17
215/40-17 if you have a lowered suspension
205/45-17
215/45-17
25 diameter that is bigger than my 18 inch wheels. 225/45-17 did not work with me it busted out 2 of my fender trims had to mod. I would go with 215/40-17. Or you could give 225/35-17 a try.
Quick question about this set-up.
I'm currently running Enkei RPM2's 17x7 et45 on 215/45s. I've got 15mm spacers up front to clear my Wilwoods. I'm not having any rubbing issues.
My new set of rims are 17x7.5 et40.
I just threw on some 225/45s. The new rims have more brake clearance so I'm going to put on some 5mm spacers, possibly 3mm.
Will I have any rubbing issues?
Colt45Magnus
Aug 27, 2024 05:03 AM
