Navigation & Audio Running speaker wire in front doors??
Old Jan 5, 2007 | 03:25 PM
Giants9595's Avatar
Giants9595
I have seen people having to drill holes in the connector of the door and then running speaker wire through that hole. What is the thickest gauge wire that can be used through this method? Does anyone have a step by step picture tutorial that tells/shows how to run the wires? How do I remove the door connector to drill it?
Old Jan 5, 2007 | 03:58 PM
FL_blue_MINI's Avatar
FL_blue_MINI
why do you need to run new wires? i have read some where on here that the stock wires can handle around 100 W. but sorry i dont have any info on rewiring the doors
Old Jan 5, 2007 | 06:29 PM
Giants9595's Avatar
Giants9595
i am running 150W speakers. Anyone have any input??
Old Jan 7, 2007 | 12:11 PM
Giants9595's Avatar
Giants9595
Old Jan 7, 2007 | 02:45 PM
borrowingamini's Avatar
borrowingamini
I did systems in both my 03 Maxima and 05 M3 using RF 6/ 1/2 components and a JL Audio 300/4 amp. Because of the molex connectors running wires to the doors was a real PITA. My exhuastive search had yeilded that the difference in sound quality by running your own (thicker) wires to the doors is minimal if noticeable at all.
Many people on the other boards ran higher wattage amps (the amp rating should determine the thickness of the wires - not the speaker per se) using factory wires and had no issues.
Your 150 watt speakers are probably rated "Peak". You would have to have one hell of an amp in your Mini to drive 150 watts per channel RMS.
Another bonus is that if you have a factory amp in the trunk (which I did on both the Maxima and M3) you can mount your amps into the trunk, remove the factory amp, then tap into the wiring harness that is already run to all the speaker locations (you would have to find what wire goes where). My system was / is LOUD and CLEAR using this method.
Edit - Sub wiring is much more important, you need thick cable there.
Old Feb 26, 2007 | 02:21 AM
Giants9595's Avatar
Giants9595
is there anyone that has done this with the mini?? I took the bolt out of the molex connector in the front door but i don't understand how it comes apart?? Can anyone help me or point me in the right direction??
Old Feb 26, 2007 | 08:37 AM
gilll7's Avatar
gilll7
pull and slide
this part right ?
Old Feb 26, 2007 | 02:32 PM
Giants9595's Avatar
Giants9595
Yes it is that piece. When i unbolt the molex connector from the car side, do i slide the connector towards me or away from me?? Have you done this personally?? Is there anyway you can give me a step by step??
Old Feb 26, 2007 | 02:45 PM
gilll7's Avatar
gilll7
yes those pics are from my audio adventure it's easy .. just difficult for me to find the right words to describe it my englisch is not that good ...
if you removed the bold just go for it .. slide then pul it out .. you'll get it .. it will not break that easy
Old Feb 26, 2007 | 11:48 PM
Giants9595's Avatar
Giants9595
Did you just use a normal drill bit to drill the molex plug out?? How did you get the wire into the door side?? When i have the molex plug unbolted and hanging out, do I slide it towards me or away from me??
Old Feb 27, 2007 | 02:09 AM
gilll7's Avatar
gilll7
i think i misunderstood
here's what you need to know :
when you pull that out the connector will release
i used a dremel with a cutter bit
and for pulling the wire trough you need a stiff wire (i used the blue one i the pics, you can see it ducktaped to the speakerwire)
hope this helps
Old Feb 22, 2013 | 03:39 AM
rockjohny's Avatar
rockjohny
i wish Gill's pictures were still on the site :(
Old Feb 22, 2013 | 07:10 AM
OldGameFreaK's Avatar
OldGameFreaK
It's not real hard...
remove the bolt and pull that corner AWAY from the body of the car then pull it towards you. It has a tab in the back.. Now pull the locking piece the the two sections will separate. You have to mess with the DOOR gap (opening and closing) to get the harness to separate completely.
That's it. I know it sounds kinda cryptic but when you look at it you'll understand.
Old Feb 22, 2013 | 08:08 AM
zcast's Avatar
zcast
If you are just running one set of wires, it is easy. I ran 16 gauge wire through the door connector. I just used a wire hanger to fish it through the flex joint. On the top of the connector there is a gap near the clip it will fit through.
Wohnson89
Jun 10, 2020 04:53 AM
JHolland
Aug 13, 2015 10:47 PM
xraycat
Aug 12, 2015 02:36 PM
OutMotoring
Aug 6, 2015 09:32 AM
