Scrapped my rear wheel on the curb while parallel parking, any fixes?
Old Jan 4, 2007 | 05:47 PM
bluesclera's Avatar
bluesclera
Any suggestions? They WERE brand new web spoke wheels .
Old Jan 4, 2007 | 05:56 PM
Hound_va's Avatar
Hound_va
How about re-taking the parallel parking portion of drivers ed. Just kidding. Lots of wheel shops will know of places to get curb damage repaired. Depending on the finish of the wheel and the amout of damage sometimes they can be fixed to look pretty darn close to new. If you could fill in your location you will probably get people from your area to chime in.
Old Jan 4, 2007 | 07:07 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Do a search in forum labled Tires, brakes. Type in "curb rash". Look down in that thread and you will find a step by step how to.
Old Jan 4, 2007 | 08:59 PM
95Viper's Avatar
95Viper
You said you have webspokes. I did a lot of research on these and the R90's. The rim is a BBS 2 piece. The inner section is painted. The outer is machined aluminum and clear powdercoated.
Now it really depends on your personality. To fix it perfectly and correctly the rim needs to be disassembled, the outer section sent to a place with a CNC machine to re-machine the lip. They will strip the finish and re powdercoat it. Then you can reassemble with correct torque specs. They will want $200+ to do this but you should negotiate it to around $100 if you just send the outer rim. We have a place right here in MI that does it.
A cheaper solution is to have a refinishing place that comes to your house. They will use tools to sand down the curb rash and clear spray it. It will look good but not OEM perfect and not powdercoat. About $100.
Old Jan 4, 2007 | 09:32 PM
kenchan's Avatar
kenchan
if it's real bad, i would just get a new wheel.
Old Jan 5, 2007 | 07:19 AM
DixonL2's Avatar
DixonL2
There's always the option of lightly sanding it down yourself and clear coating. It's clunky but... it staves off corrosion for a while. Worked on my '84 GTI rims, and held up well. That's on a 23 year old car. For yours... I'd hit up a new wheel, or else have it done.
How bad was the hit?
Old Jan 5, 2007 | 10:23 AM
bluesclera's Avatar
bluesclera
about 2cm long arc shaped scrap along the outer circumferance of the aluminum ring. killing me. I've found a local shop that will fix it for $100.
thanks guys.
Old Jan 5, 2007 | 10:48 AM
95Viper's Avatar
95Viper
The local shop will fix it for $100 but it won't be powdercoated clear. It will be sprayed clear. Not that I'm saying that is so bad...just be aware.
NYXF56JCW
Nov 17, 2024 05:06 AM
SosoMINI
Nov 22, 2015 03:17 PM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
