Headlight out - the first thing to go wrong with my MINI
Old Dec 25, 2006 | 02:58 PM
Ladidah's Avatar
Ladidah
One of my headlights is out. I have a 2005 MCS with Xenons, but it isn't the Xenon that is out, it's the daytime running light/high beam light.
What do I need to do to replace it? What do I need as far as a replacement, and how do I access the light? The manual says go to the dealer; is that necessary?
I am hoping it can be replaced very cheaply and easily..
Thanks!
Old Dec 25, 2006 | 03:02 PM
Motor On's Avatar
Motor On
You need an H7 light; can get as cheap as $10-20 but you get what you pay for may find a $100 bulb to last longer and be brighter if you can afford it.
Here is the how-to but you'll have the lower bulb and things will look slightly different on the top.
Hope this helps let me know if you have any questions. I'll answer themthe best I can.
Old Dec 25, 2006 | 03:30 PM
Ladidah's Avatar
Ladidah
Can I get the cheaper bulbs at any auto place store? I can't really swing $100 bulbs right now. Thanks for the great pictures.
Old Dec 25, 2006 | 04:23 PM
NMgokart's Avatar
NMgokart
Yep, any H7 will work. Just make sure you replace both, for equal color/brightness and longevity.
Old Dec 25, 2006 | 05:09 PM
Motor On's Avatar
Motor On
Any H7 at autozone will do, should be able to get 1-2 years from it
Old Dec 25, 2006 | 05:25 PM
chows4us's Avatar
chows4us
http://www.suvlights.com/index.php?cPath=37
$35 top of the line ... +50 bulb
Old Dec 25, 2006 | 07:18 PM
rkw's Avatar
rkw
If it's a 2005, I presume it is still under warranty and the dealer will replace it for free.
Old Dec 25, 2006 | 07:29 PM
Ladidah's Avatar
Ladidah
Really? Headlights are covered? It is still under warranty.
Old Dec 25, 2006 | 08:17 PM
Motor On's Avatar
Motor On
Actually yes if you're under 50k and 4 years they will likely replace them for you, if you're near the dealer it certainly is worth a try.
Old Dec 25, 2006 | 08:39 PM
Wake|MCS's Avatar
Wake|MCS
Yeah don't touch your headlights. Your dealer will likely void your warranty on the pricey Xenons (like they did mine, not that i have any warranty any more) and maybe even try to void your electrical system warranty if they are *******s about it...
Old Dec 25, 2006 | 09:13 PM
rkw's Avatar
rkw
Yes, all bulbs inside and out are covered. During the initial 3-year/36K miles, maintenance coverage is really quite complete and even includes the wiper blades.
Old Dec 26, 2006 | 07:57 AM
Ladidah's Avatar
Ladidah
Whoo hoo! That settle that I guess. Thanks, and I'll remember all this when it is no longer under warranty.
Motown
Apr 20, 2018 09:31 AM
Dec 23, 2015 10:36 AM
dyeLucky
Aug 7, 2015 07:10 AM
