Dupli-color wheel paint
Old Dec 23, 2006 | 10:50 AM
Mr. D's Avatar
Mr. D
Has anyone tried the dupli color aersol wheel paint on their stock rims?
I was looking at their website which has great video clips on all their products. I wanted to paint my stock 17' s lites until I save some more dinero for aftermarket rims.
thanks-Mr. D
Old Dec 23, 2006 | 11:19 AM
kenchan's Avatar
kenchan
haven't tried their wheel paint, but dupli-color in general is high
quality paint. i wouldn't mind spot bonding up my used x-lites
that got some rimmage and spraying them down next summer.
Old Dec 24, 2006 | 08:29 AM
Mineon's Avatar
Mineon
I've got some that I was going to use, but never got around to it. I did have a friend that used the Duplicolor wheel paint on some wheels for his daily driver a couple of years ago. IIRC he scuffed up the original paint, then used two coats of the Duplicolor and a coat or two of their clearcoat on them. It held up pretty well for the year or two he used the wheels. It is more fragile than the original paint or getting them powdercoated, and you have to be a bit careful with what you use to clean them though (some of the harsher, acidic wheel cleaners can damage the paint).
-Keith
Old Dec 24, 2006 | 08:56 AM
ScottRiqui's Avatar
ScottRiqui
thanks-Mr. D
The results can be great, but as with any painting, you determine your results with the prep-work, before you even spray the first coat of paint (this is even more true when using rattle-can paint).
I'd have the tires unmounted, and bead-blast the wheels if you can. If you can't have them blasted, I'd at least wash/de-grease them, and then wet-sand them with some 400-grit WetOrDry sandpaper until the entire wheel has a dull satin finish.
After the blasting or sanding, apply at least two coats of the color, heavy enough that the finish doesn't look "dry", but light enough that you don't get runs or sags in the nooks and crannies. Then follow it up with two coats of the clear, applied the same way. You can go a little heavier on the second clearcoat, since the still-tacky first coat will help keep the second coat from running, and the heavier second coat will "flow out" better and give you a smoother finish.
Old May 31, 2007 | 01:17 PM
Motor On's Avatar
Motor On
bump
Old May 31, 2007 | 05:04 PM
kenchan's Avatar
kenchan
motoron- not this weekend, but maybe next weekend i might do the
legacy wheel fix. can't really do it on a rainy humid day. will keep you
posted. i bought the duplicolor silver paint and clear. i need to spot
bondo and prime first though (thanks to the wifey's articulate driving
into curb).
Old May 31, 2007 | 05:14 PM
Motor On's Avatar
Motor On
I'm not sure I have that kind of Patience
Old May 31, 2007 | 06:34 PM
kenchan's Avatar
kenchan
your call.
sevin
May 2, 2026 06:11 AM
Bennyboy
Aug 18, 2015 07:28 AM
Powershift
Aug 16, 2015 05:14 PM
Dashdog
Aug 10, 2015 06:17 AM
O4mcs
Aug 6, 2015 05:42 AM
