225/30/18 on 18X7 52mm Possible
Old Dec 20, 2006 | 08:53 AM
JustJAY's Avatar
JustJAY
I was wondering if this would be possible on an MCS with H-Sport springs and Ireland fixed camber plates, or at least a little rubbing. Thanks in advance.
Old Dec 20, 2006 | 09:03 AM
kenchan's Avatar
kenchan
might rub the inside now, but if you do, just add a 3-5mm spacer.
should fit.
i havent seen too many 52 offset wheels for the MINI's so make
sure the PCD and center bore is correct. meaning, 100x4 lug 56.1mm diameter.
Old Dec 20, 2006 | 09:08 AM
JustJAY's Avatar
JustJAY
The 52mm offset are for the R105s, or at least that is what I have found out.
Old Dec 20, 2006 | 09:45 AM
MarioKart's Avatar
MarioKart
Vendor
I'm running 225/40/18 with 42offset lowered on Hsport and no problems. You might need some spacers to bring the wheels out.
RavSpec
Feb 28, 2012 06:03 PM
lovethecorners
Tires, Wheels, & Brakes
Feb 10, 2011 08:24 PM
Alex@tirerack
Oct 4, 2002 03:17 PM
