Idler pulley?
Old Dec 19, 2006 | 08:06 PM
euro_tuned's Avatar
euro_tuned
Idler pulley?
Have a slight rattling noise coming from the engine bay (passanger side). It is very low and sounds like a loose idler pulley (bad ball bearing)confused: . It is there when the car idles, it goes away when the revs go up. I have a 2005 Cooper. Wonder if any1 else has had a similar problem.
Old Dec 20, 2006 | 06:38 AM
gizzer777's Avatar
gizzer777
My 03 had it
My 03 MC had a bad bearing in the idler pulley at 23,000 miles.
Old Dec 20, 2006 | 06:48 AM
MINISQL's Avatar
MINISQL
Does it go away when you push the clutch in? Some throw out bearings chatter a little bit with no load on them.
Old Dec 20, 2006 | 06:58 AM
gizzer777's Avatar
gizzer777
Mine was definately the idler pulley
On my 03, replacing the pulley stopped the problem completely
Old Dec 21, 2006 | 04:26 PM
euro_tuned's Avatar
euro_tuned
It is not affected by engaging the clutch. It comes on after about 20-30 minutes of city driving. I am pretty sure it is the idler pulley, but I hope I would not have to replace the whole tensioner.
Old Dec 21, 2006 | 07:31 PM
SumWon's Avatar
SumWon
So do you think the issue is the tensioner pulley or the idler pulley? The only non-OEM replacement for these that I have seen is GTTuning. I have both and they are works of art, but they are pricey. OEM may be a cheaper choice.
Old Dec 22, 2006 | 05:13 PM
euro_tuned's Avatar
euro_tuned
idler more likely
I believe it is the idler pulley since I put a stethoscope and it sounded louder than the tensioner pulley. However not 100% sure. I was looking at the GTT stuff and I would rather bite the bullet and buy their twin bearing pulley. I know they make great quality products and it will probably last longer. I guess I will find out if that fixes the problem when I get my pulley installed!
Old Dec 23, 2006 | 09:04 AM
SumWon's Avatar
SumWon
While I had mine apart, I went ahead and did the crank pulley and the tensioner stop too. I have been very happy with the combination.
Old Dec 23, 2006 | 09:49 AM
k-huevo's Avatar
k-huevo
To check idler pulley health, take tension off the belt, grab the pulley and wiggle, if it moves, torque the bolt (sorry I don’t have the spec with me but it’s in the Bentley and it’s not much 35 ft-lbs? because it fastened to the thin camshaft chain cover) and try to get movement. Mine (MCS) required re-torque at fairly low mileage and has not loosened since. If it has rocking movement and tightening does not stop it, then replace the pulley.
The same diagnostic procedure is valid for the tensioner pulley. Most tensioner failures are because the damper failed (MCS), or cracks formed due to overextending the tensioner arm contacting the engine mount bolt that protrudes directly above the mid point in the arm’s arc (MCS), or the bearing bolt had loosened allowing it to operate in an unstable state (valid for both arm bolt and pulley on the MC).
Old Dec 24, 2006 | 11:51 AM
euro_tuned's Avatar
euro_tuned
thank you for all your replies . I will attempt to fix the problem after the holidays.
Old Dec 28, 2006 | 07:07 AM
Aeromax's Avatar
Aeromax
My idler pulley started making noise a few days ago, and yesterday it just crapped out on a drive up to vermont and shredded my belt. Had it towed 20 miles to my parent's place, and now i'm waiting for a belt and pulley to be UPSed to me because the mini dealer doesn't have them in stock. I'd fix the pulley before it goes on you.
Old Dec 29, 2006 | 03:07 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
just incase this is not it. if you have a pulley, check to make sure it's tight. i had a car come in a month ago that sounded like a bad bearing, but it ended up being the supercharger pulley bolts where not tight and the pulley had loosened up. since i had not installed this i had no idea what was done, but we jacked up the motor and took it off and replaced it with a new pulley since it worn down. so far no other problems, but it sounded just like a bad bearing. good luck
chad
detroit tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Dec 31, 2006 | 07:37 PM
euro_tuned's Avatar
euro_tuned
harmonic balancer bolt
I took a better look wierd thing is that the harmonic balancer's bolt looked like moving. However the balancer itself did not have any singns of movement. Mayb needs to be retightened. I used a stethoscope and one of the tensioner pullies deffinetly sounded noisyer than normal. Mini said that the pulleys cannot be ordered separetaly but I have to replace the whole tensioner. Which is ok because its not that expensive. I will let you guys know if that fixes the problem .
Old Dec 31, 2006 | 08:18 PM
norm03s's Avatar
norm03s
How much did they say it would ( tensioner ) cost?
Check with Classic they are a vendor on this board and give NAM people a discount for the best price.
Old Jan 1, 2007 | 01:26 PM
euro_tuned's Avatar
euro_tuned
tensioner cost
I am in Canada so Classic is out of the question as they are not allowed to ship directly to Canada. Mini quoted me $155 CDN. I get a special shop discount. The price is reasonable considering you get the whole tensioner assembly. Thanks for the help .
Old Jan 4, 2007 | 07:04 PM
euro_tuned's Avatar
euro_tuned
Update
Bought the part. Should be able to put it in Saturday. Anyone have the torque specs for the tensioner bolts?
Old Jan 7, 2007 | 03:56 PM
euro_tuned's Avatar
euro_tuned
Still hearing the noise
Still hearing the same noise after replacing the belt tensioner. It sounds like something is loose only comes on after the car warms up. Im gonna wait till it gets really loud so that I can have a mechanic check it.
Old Jan 7, 2007 | 05:42 PM
Detroit Tuned
Vendor - 15 Years
i just replaced my first Idler pulley this weekend for a customer. the car had 104K on it and it was not making any noise, but after we pulled it off, the bearing had slop in the up-down motion (while on the car). there was no in out motion (again while it was on the car). this will not help your problem, but a bit of info NAM may like.
euro_tuned, where are you from?
Old Jan 8, 2007 | 06:40 PM
euro_tuned's Avatar
euro_tuned
I am in Toronto, Canada. I am starting to think its one of the heat shields near the headers. I can hear the rattle sometimes when going over bumps. Today no sign of it . Like I said I will wait till it gets loud and take that puppy apart. The way I see it the tensioner wasn't a waste of time since it was louder so at some point I would have ended up replacing it.
Old Jan 8, 2007 | 06:55 PM
Detroit Tuned
Vendor - 15 Years
your not to far away from me. you could always drive on down and spend a few hours at the shop. find the rattle, get some mods, have some fun.
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
