Tire Pressure for Michelin Pilot PE2's
Old Dec 13, 2006 | 02:59 PM
qluber's Avatar
qluber
Just switched to some Michelin Pilot Exhalto PE2's (215-45-17). I started out with 37psi all around, the side walls felt a bit mushy in the turns. I subsequently upped the pressure to 42psi all around, quite a bit more stable now. Just wondered if anyone has experimented with pressures on these tires to find the "happy medium" for tire wear, handling, road noise, fuel economy? Chime in here if you have any testimonials!
Old Dec 13, 2006 | 04:08 PM
kenchan's Avatar
kenchan
i would use 34psi and break them in a little.
Old Dec 13, 2006 | 05:05 PM
qluber's Avatar
qluber
Break in? That's a new one on me.........................can you elaborate?
Old Dec 13, 2006 | 06:15 PM
kenchan's Avatar
kenchan
sure. tires are molded and outer surface is exposed to mold release lube.
that lube is still on your tires when new and prevents the tires from gripping well
to the surface. you break the tires in by driving on them to wear it off and
to wear the treads to your suspension geometry and driving habits.
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
