Drivetrain Best belt for 17% and 2% crank? No slip
Old Dec 7, 2006 | 11:02 PM
MarioKart's Avatar
MarioKart
Vendor
I just picked up my car from the shop. I had a new belt put on and had the lighten crank pulley put on again for the third time. I noticed that my car doesn't hit 18psi any more or very rarely only 15psi. I can hear the belt slipping and squeaking under full load. I want to know the perfect and best belt to use for my set up Alta 17% s/c pulley and M7 2% crank pulley. I thought I read somewhere the best was a Gatorback or something. I also need the measurments.
M
Old Dec 7, 2006 | 11:06 PM
El_Griton's Avatar
El_Griton
your makin me worry about my 19% thats on the way!!! I hope you get it figured out but damn man.
Old Dec 7, 2006 | 11:15 PM
MarioKart's Avatar
MarioKart
Vendor
You must be following some of my threads. Before I took the car in this last time the car was driving great and making great power. Now this new belt is f*cking up. It almost feels like the shop changed my 2% crank pulley to a 0%.
I'm sick of all this.
Old Dec 7, 2006 | 11:24 PM
El_Griton's Avatar
El_Griton
yeah i have been keepin an eye on your other posts. bums me out that all that stuff is going down. hope you get it workin soon.
Old Dec 7, 2006 | 11:28 PM
MarioKart's Avatar
MarioKart
Vendor
Thank you for your support. Like I have said before, I guess I'm just the .01% that has had problems with a crank pulley.
Old Dec 7, 2006 | 11:30 PM
El_Griton's Avatar
El_Griton
on a totally off topic note, I lived in Santa Barbara for 3 years and miss it dearly! I would make trips to ventura everyday after school to surf.
Old Dec 7, 2006 | 11:32 PM
MarioKart's Avatar
MarioKart
Vendor
Not sure where you live now, but if its close you should come to Ventura and we can grap some lunch.
M
Old Dec 7, 2006 | 11:34 PM
El_Griton's Avatar
El_Griton
that would be a hell of a drive........I live in south carolina now.
Old Dec 8, 2006 | 12:20 AM
JSWMCS's Avatar
JSWMCS
the gates 6PK 1374 JCW belt should work fine with the 17% & 2%.
look to see if the M7 CP is installed it is engraved on it 2%. the only black 0% CP is th alta.
- john
Old Dec 8, 2006 | 12:31 AM
JSWMCS's Avatar
JSWMCS
also maybe you should try the alta altanator pully designed for the oversized crank pullies. it may help with the slpiing issue??
-john
Old Dec 8, 2006 | 12:32 AM
JSWMCS's Avatar
JSWMCS
-john
Old Dec 8, 2006 | 09:00 PM
bomboasy's Avatar
bomboasy
Curious to know how the Alta Alternator would help with this problem. My understanding is that it helps the alternator to return to normal RPM, from the over spining that it is doing due to the smaller pulley at the SC. It is 5% oversized to let the alternator spin at the speed it was designed to work at, avoiding electrical issues. Am I wrong on this or missing something? Thanks.
Bomboasy
Old Dec 8, 2006 | 11:41 PM
JSWMCS's Avatar
JSWMCS
better belt wrap with larger alt pulley.
Old Dec 10, 2006 | 05:26 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Get a Goodyear Gatorback belt.
RobbyD
Jan 29, 2019 01:22 PM
vulkandino
Oct 31, 2015 08:29 PM
VanisleRyan
Sep 30, 2015 08:35 PM
Sep 28, 2015 09:13 AM
daviday
Sep 25, 2015 01:31 AM
