Interior/Exterior Where's the wiring for the p. outlet in boot?
Where's the wiring for the power outlet in boot? I have a 2003 MCS and would like to install an outlet in the hole after I remove the plastic blank. I could not find the wiring harness, it must be tucked up pretty good.
It is right there !
That really large RED cable running inside the acess cover is you battery cable ...
I made an incision into the cable, inserted a wire (with fuse in line) with a flat spade connector into the slot, sealed it with silicone.
Grounded a wire to one of the many good grounds avaliable.
A universal sig lighter for $5.99
Good to go ...
Good to go ...
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
67morris
Dec 1, 2015 12:53 PM
Sc00terbum
Sep 11, 2015 09:07 AM
