Insane Brake Dust with JCW brakes
Old Nov 25, 2006 | 09:11 PM
mini_racer's Avatar
mini_racer
I have the JCW brake kit on my '06 and the brake dust is absolutely insane. My 17" S-lites are dirty after only about 50 miles of mixed driving. What are the common pad upgrades to minimize dust, yet still deliver the same braking performance?
Thanks for any help.
Old Nov 25, 2006 | 09:15 PM
SandiePepper's Avatar
SandiePepper
I switched wheels to the 18" JCW but don't have that much dust, try waxing the wheels and see if that helps, I also use a cleaner with a brakedust repellent in it, seems to help a little.
Old Nov 25, 2006 | 09:26 PM
mitchman's Avatar
mitchman
The first 3000 miles are bad as the pads are breaking in. But then it gets better. The dusting never goes away, but it doesn't happen as quickly. (we have white wheels)
There are pad you can buy that have less dusting, but you'll sacrifice performance.
Old Nov 25, 2006 | 09:40 PM
mini_racer's Avatar
mini_racer
Thanks for the responses.
Grrrrr, I just might have to live with it, 'upgrading' to lower braking performance does not seem like a good upgrade.
I presently use the tactic of cleaning often and polishing/waxing but it's wearing me out.
Also, just turned over 3400mi., so if it is going to get better, now would be a good time.
Old Nov 25, 2006 | 09:56 PM
mitchman's Avatar
mitchman
Just stop using the brakes so much.
Just a stupid tip.......clean the wheels when they are stone cold. Otherwise they brake dust doesn't come off nearly as easily.
Old Nov 25, 2006 | 10:42 PM
XAlfa's Avatar
XAlfa
I highly recommend matte black wheels.
Old Nov 25, 2006 | 11:19 PM
GoodFinder's Avatar
GoodFinder
mitchman - that is actually a very good tip, to clean them when cool, as much as possible
Old Nov 26, 2006 | 05:29 AM
THE ITCH's Avatar
THE ITCH
Please see this post and add your desire to get a mfg. to make a good performance low dust alternative. Thanks Steve
https://www.northamericanmotoring.co...BRAKE+PAD+DUST
Old Nov 26, 2006 | 06:43 AM
mitchman's Avatar
mitchman
Good point "THE ITCH". You can send your pads to Carbotech (and Porterfield, and probably others) and they will resurface them with the compound of your choice. And it doesn't cost much more than just buying new pads.
But I still say that soft pads cause dust. I don't believe JCW rotors are softer than other rotors. I think that's just crazy talk .
Here's a good thread about brake pads from people with more experience than me: http://sccaforums.com/forums/thread/221088.aspx
Old Nov 28, 2006 | 01:07 PM
machineguncharley's Avatar
machineguncharley
XAlfa...
You just made my day! I hadn't been thinking about the brake dust problem until I read it, but next week I'm having the JCW brake kit installed with the black 18" JCW wheels. I had been torn between the other JCW wheels and the black, but for some reason decided to go with black. Now I'm glad I did!
Chuck
Old Nov 28, 2006 | 01:50 PM
XAlfa's Avatar
XAlfa
Originally Posted by machineguncharley
XAlfa...
Chuck
Yes, you will be happy. But...you would be even happier with lighter, smaller wheels and sticky non-runflats. Check out the TDR PR1/1.2 for something similar to the R105 in appearance. 17x7, 16lbs, $160 each.
Old Nov 28, 2006 | 04:32 PM
speednut's Avatar
speednut
or "gun metal gray" works well too...
Had same issues with craptastic brakes. When I switched to my new wheels, I waxed them with Meguirers NXT synthetic wax (no carnuba). Now I simply hose the wheels off when I start my car wash and most of the brake dust rinses off. When I'm done washing the car, I use a wash mit (different one just for the wheels) and the leftover soap suds to finish cleaning them. No wheel cleaner is needed. I'm almost at the 3000 mile since my last waxing and will do it again when I rotate the tires.
Old Nov 28, 2006 | 04:44 PM
Larry Clemens's Avatar
Larry Clemens
Get some Hawk HPS pads if they have a JCW size. They have awesome stopping power and almost no dust.
Old Nov 28, 2006 | 05:25 PM
speednut's Avatar
speednut
Whoa, hang on here...
Thank you for being helpful Larry (meant with true sincerity), but please let's not hijack this thread with any further brake pad suggestions unless you know they make them for the JCW cBBK. AFAIK, Carbotech is the only alternative for replacement pads at this time. I'd certainly welcome hearing about any other discoveries though.
sevin
May 2, 2026 06:11 AM
theblackfalcon
Oct 11, 2015 09:49 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
