R50/53 Removal of 2006 MCS exhaust tips
Old Nov 25, 2006 | 05:37 PM
gary87xj6's Avatar
gary87xj6
I want to remove the OEM exhaust tips from my 2006 Cooper S and add some nice turned up tips while I await for funds for an exhaust upgrade, (thinking of a Borla street setup). I can not see into the small hole on the tip (which I assume is access hole) to a screw of somekind to remove the tip.
I'm thinking it's an allen head. Can I get some help?
Gary
Old Nov 25, 2006 | 06:06 PM
ARTSJCW's Avatar
ARTSJCW
It is an Allen head. The mod is easy to do [I did it and am not very mechanically inclined]. Unfortunately I cannot remember the size.
Good Luck
Old Nov 26, 2006 | 07:28 AM
SilverHawk's Avatar
SilverHawk
It is an Allen head. It is a little trickey to get to because you can't see up inside the access hole. Good luck.
Old Nov 26, 2006 | 04:01 PM
SilverHawk's Avatar
SilverHawk
When you put your new tips on be sure to use loctite.
Old Nov 26, 2006 | 04:29 PM
gary87xj6's Avatar
gary87xj6
thanks for the suggestion, if i use the loctie will I be able to remove the tips when I upgrade the exhaust system?
gary
sevin
May 2, 2026 06:11 AM
ASRman
Aug 13, 2015 09:33 AM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
