Drivetrain mini madness jcw filter
Old Nov 11, 2006 | 07:36 PM
onrails's Avatar
onrails
Has any one installed the mini madness jcw air filter??
I have tried, it does not fit any thing like the original.
Old Nov 12, 2006 | 06:49 AM
mbcoops's Avatar
mbcoops
If you're not satisfied, another option would be the foam ITG filter. I did some reading on the company, and they put out a quality product. I believe you can get it from myminiparts.com
Edit - I also used it in my JCW intake, and I liked it better than the stock filter. A little more sound, no more power, and you can clean/oil it instead of changing.
mb
Old Nov 12, 2006 | 08:04 AM
belosic's Avatar
belosic
I also have the ITG filter in my JCW box (flap removed). More SC whine, and you can hear a nice "squish" sound when you let off the throttle quickly. I got mine from mymini.
Old Nov 12, 2006 | 05:35 PM
Philip Rushing's Avatar
Philip Rushing
I just installed a mini madness filter in my '04 JCW. Not hard to do. They suggest a few mods while you're in there that are real easy to do. The instructions come on a disc, though. If you do not have a pc in your garage (I do) you might print it out as a .pdf.
It comes from the factory oiled, although it doesn't say that explicitly. Also I bought some recommended oil for the filter, but cannot find the specs on how much oil to use when I clean it next time. I will contact them before then I hope.
Beats the hell out of the paper filter for a hundred plus bucks a pop.
Old Nov 13, 2006 | 08:19 AM
MINI-Madness's Avatar
MINI-Madness
JCW filter
If you have an issue with the filter please give us a call. The filter fits perfectly so if your having trouble we can help.
Old Nov 13, 2006 | 10:16 AM
fritznw's Avatar
fritznw
I have this filter in my '06 JCW and it was definitley worth the price compared to the original paper filter. As stated by MM, if you are having problems with it, give them a call, they'll be glad to help out. You'll be very happy with the boost in performance you'll get.
Dudley
Old Nov 13, 2006 | 05:42 PM
onrails's Avatar
onrails
Dudley
does your filter have tread groves on the inside
Old Nov 13, 2006 | 05:47 PM
onrails's Avatar
onrails
thanks Philip i do have a computer & a printer & the disk
still did not fit.
i was just thinking someone else might have run into this problem
Old Nov 13, 2006 | 09:02 PM
MisterMINI's Avatar
MisterMINI
I installed the MINI Madness JCW filter and it fits like a dream. This might sound like a silly question, but are you sure you have a JCW intake and not the stock intake? If you have the JCW then there is no way it won't fit unless you were shipped the wrong item.
Old Nov 14, 2006 | 07:15 AM
Zac's Avatar
Zac
Hey, i have an 05 JCW, i was wondering if there is a dyno chart for the Mini-Madness filter? If there is can you post it?
Thanks,
Zac
Old Nov 14, 2006 | 03:52 PM
onrails's Avatar
onrails
yes i do have the jcw intake, they shipped the wrong one, just confirmed with them
Motown
Apr 20, 2018 09:31 AM
bc219
Aug 10, 2015 11:22 AM
PelicanParts.com
Aug 7, 2015 08:39 AM
